Control Keyboard LEDs? SOLVED!
10-15-2023, 09:44 AM (This post was last modified: 10-15-2023 06:34 PM by toml_12953.)
What values can I send to a USB keyboard to turn on the LEDs?
My keyboard reading program is coming along but I'd like the LEDs to reflect the state of the Caps Lock, Num Lock, and Scroll Lock keys.
Thanks for any info!
I found the codes. It's very simple.
Use USBSend({n})
where n is:
1 - Num Lock
2 - Caps Lock
4 - Scroll Lock
You can combine them to turn on or off combinations
USBSend({5}) - Turns off Caps Lock and turns on Num Lock and Scroll Lock
USBSend({0}) - Turns off all LEDs
USB Send({3}) - Turns off Scroll Lock and turns on Num Lock and Caps Lock
You should get the idea.
Tom L
Cui bono?
