Enter key ignored?
10-18-2023, 09:20 PM
Enter key ignored?
Is there any difference entering:
0
Enter
6
enter
2
1
and
0
Enter
6
enter
2
enter
1
I am getting the same result. Is it a stack overlow?
10-19-2023, 02:05 AM
RE: Enter key ignored?
On what machine? It matters for this question....
10-19-2023, 03:02 AM (This post was last modified: 10-19-2023 03:06 AM by teenix.)
For the 67
         Stack  X Y Z T
0               0 0 0 0
Enter           0 0 0 0
6               6 0 0 0
enter           6 6 0 0
2               2 6 0 0
/               3 0 0 0
1               1 3 0 0
+               4 0 0 0
*               0 0 0 0
and
0               0 0 0 0
Enter           0 0 0 0
6               6 0 0 0
enter           6 6 0 0
2               2 6 0 0
/               3 0 0 0
enter           3 3 0 0
1               1 3 0 0
+               4 0 0 0
*               0 0 0 0
cheers
Tony
10-19-2023, 03:08 AM (This post was last modified: 10-20-2023 08:14 AM by brouhaha.)
In traditional HP RPN, ENTER disabled stack lift, so while ENTER duplicates X into Y, pushing Y and Z into Z and T, a number keyed in immediately after ENTER does not lift the stack again.
Most calculators that use traditional RPN have a manual appendix describing stack lift disable, and enumerate what operations do it.
RPL.calculators (28, 48, 49, 50) do not work the same way.
10-19-2023, 05:54 PM
(10-19-2023 03:08 AM)brouhaha Wrote:  RPL.calculators (28, 48, 49, 50) do not work the same way.
Specifically, if there is an open command line (i.e. you are typing stuff in), Enter evaluates the command line. If there is no command line, Enter duplicates the object on stack level 1. If the stack is empty, pressing Enter gives a "Too Few Arguments" error.
10-19-2023, 10:25 PM
and let's not mention the weirdness of the 9100...
-J
