date(time) python libraries
10-22-2023, 12:02 PM
Am I right that there are no date/datetime libraries available on the Prime's MicroPython? I looked at the Help system as well as the output of Code: help('modules') and could not see any related libraries besides "utime" which does something else by the looks of its member functions How do you accomplish date/time calculations within Prime's Python environment? Thanks! |
10-28-2023, 06:39 AM
RE: date(time) python libraries
Python for HP Prime is still in the development stage, and not everything is available. At the moment, you can use the hpprime library to reference PPL instructions.
For example: Code: import hpprime as h There are also DDAYS, DAYOFWEEK and TICKS instructions available. Best wishes, Piotr |
10-28-2023, 07:53 AM
(10-28-2023 06:39 AM)komame Wrote: Python for HP Prime is still in the development stage, and not everything is available. At the moment, you can use the hpprime library to reference PPL instructions. Ah, I didn't think of calling PPL routines. Thanks for the suggestion |
