Why does my HP48G program give this error??
10-27-2023, 11:28 PM (This post was last modified: 10-28-2023 03:08 PM by DM48.)
Why does my program give me a \.S Error: Bad Argument Type ??
I have written a lot of these integration routines very similar to this on my HP48 but this one is not cooperating. It works when I put in numbers in place of variables. However, when I had the variables back in the program ceases to function.
I typed the below in by hand so I may have a few errors. I have attached a screenshot of the formula part as a reference.
\<< 48 58 12 6 \-> ID OD H OC
\<< ' \.S (0,H/2, \.S (-OC, \v/ (H/2-y^2) - OC, \v/((OD/2)^2 - x^2) - \v/((ID/2)^2-x^2),x),y)' \->NUM >>\ \>>
\( \large \int_{0}^{\frac{H}{2}}\int_{OC}^{\sqrt{\left ( \frac{H}{2} \right )^2-y^2}\: \: +OC}\sqrt{\left ( \frac {OD}{2} \right )^2- x^2} \: \: - \: \: \sqrt{\left ( \frac {ID}{2} \right )^2- x^2} \)
Attached File(s) Thumbnail(s)
HP48GX, HP42s and DM42.
10-28-2023, 11:48 AM
RE: Why does my HP48G program give this error??
With only numbers it will not work. I feel like I am in the twilight zone. I have tried RAD and DEG.
10-28-2023, 04:42 PM
In one place you have \(\sqrt{H/2-y^2}\); I guess the \(H/2\) should be squared.
Nigel (UK)
10-28-2023, 04:54 PM
(10-28-2023 04:42 PM)Nigel (UK) Wrote:  In one place you have \(\sqrt{H/2-y^2}\); I guess the \(H/2\) should be squared.
Nigel (UK)
Nigel, I want to thank you from the bottom of my heart. I have typed this equation in no less than fifty times between yesterday and today and every time I must have left that out. I have checked, rechecked, and checked again. Deleted, swapped phones, used a real 48G, etc.
It is now working. Thank you!
