Just bought a new old stock HP-12C Gold
10-30-2023, 04:44 AM (This post was last modified: 10-30-2023 05:01 AM by lvt.)
So after almost a year of using the HP-12C Platinum, I decided to add a gold version of the 12C.
I'm not sure if other 12C users would agree, but I found that the old 12C has better screen with bolder numbers and better keypads (it's softer so I don't have to use force to press).
I don't know what the 6-pin connector is for though.
HP-12C Gold / HP-12C Platinum
10-30-2023, 04:47 AM (This post was last modified: 10-30-2023 04:58 AM by lvt.)
RE: Just bought a new old stock HP-12C Gold
[Image: IMG20231030113508.jpg]
10-30-2023, 04:55 AM (This post was last modified: 10-30-2023 04:59 AM by lvt.)
[Image: IMG20231030122412.jpg]
10-30-2023, 05:22 AM
I've noticed the keyboard as well with the newest 12C's, they do seem to require a more firm press compared to the older versions.
The connector is intended for flashing the 12C with different firmware, operating system.
HP did publish a software development kit, I don't think this is online anymore though.
10-30-2023, 05:31 AM (This post was last modified: 10-30-2023 05:31 AM by lvt.)
(10-30-2023 05:22 AM)HP-12C Wrote:  I've noticed the keyboard as well with the newest 12C's, they do seem to require a more firm press compared to the older versions.
Thanks for confirming, so it's a fact though.
(10-30-2023 05:22 AM)HP-12C Wrote:  The connector is intended for flashing the 12C with different firmware, operating system.
What do you mean by "different firmware, operating system"?
I'm familiar with rooting/flashing smartphones, maybe I would give my 12C a try.
10-30-2023, 06:04 AM
I'm not a computer programmer but this may help:
https://www.hpmuseum.org/forum/archive/i...-5171.html
10-30-2023, 07:48 AM
(10-30-2023 06:04 AM)HP-12C Wrote:  I'm not a computer programmer but this may help:
Thank you.
10-30-2023, 07:50 AM (This post was last modified: 10-30-2023 07:51 AM by lvt.)
BTW, is it normal that I can change screen contrast on my 2015 12C?
From what I've read it's only possible on the newer 12CP.
10-30-2023, 04:55 PM
Unfortunately the published SDK for the 12c only seems to be for the older AT91SAM7L128-based model, not the 2015+ model based on the ATSAM4LC2CA. The differences are probably fairly minimal, though, but I haven't looked into it to verify.
The programming cables are a bit different, though; the cable for the ATSAM4LC2CA is actually a bit simpler, since it speaks USB instead of TTL serial and doesn't need the level shifting chip.
10-30-2023, 05:37 PM
Eric, it is so possible to flash the 15c firmware into these 12c?
10-30-2023, 05:55 PM
(10-30-2023 05:37 PM)Jlouis Wrote:  Eric, it is so possible to flash the 15c firmware into these 12c?
The 15c LE firmware can be flashed on the pre-2015 ARM-based 12c calculators. The 15c CE firmware can be flashed on the post-2015 ARM-based 12c calculators.
10-30-2023, 06:05 PM
Hmm, now I see why my 12C's screen is identical to the 15C's screen, segment by segment.
I was wondering why there are USER and GRAD signs on the screen while there is no related function.
10-30-2023, 06:17 PM (This post was last modified: 10-30-2023 06:23 PM by lvt.)
I guess that the same screen has been used for more than one calculator?
And if we flashed the 12C with 15C firmware, how about the keypad?
[Image: IMG20231031022007.jpg]
10-30-2023, 07:37 PM
I believe some news are approaching.
[Image: zipper-mouth-emoji-300x300.png]
Greetings,
    Massimo
