HP Prime for advance statistics
09-04-2014, 07:02 AM
Does anyone know of a one way anova and or multiple regression app that can be loaded to the HP Prime?
09-04-2014, 03:28 PM
RE: HP Prime for advance statistics
(09-04-2014 07:02 AM)pr011235 Wrote:  Does anyone know of a one way anova and or multiple regression app that can be loaded to the HP Prime?
I am attaching a pdf file that contains several articles (from the HP Solve newsletter) for the HP 39gII that perform ADVANCED types of regression. These programs should work with the HP Prime. These programs show the power of the HP 39gII and the HP Prime in performing sophisticated regression calculations.
Namir
PS: Here is the code for about the dozen programs in the attached article, so you can copy and pasted them easily in the HP Prime emulator or the Connectivity Kit.
MLR2
EXPORT MLR2(MatX,VectY)
  LOCAL i,j,y,Rsqr;
  LOCAL lstDimX,NumRowsX;
  LOCAL YMean,Sum1,Sum2,Yhat,RegCoeff;
  // calculate the regression coefficients
  RegCoeff:=LSQ(MatX,VectY);
  // calculate the number of data points
  lstDimX:=SIZE(MatX);
  NumRowsX:=lstDimX(1);
  // calculate ymean
  Sum1:=0;
  FOR i FROM 1 TO NumRowsX DO
    y:=VectY(i,1);
    Sum1:=Sum1+y;
  YMean:=Sum1/NumRowsX;
  // calculate the coefficient of determination
  Sum1:=0;
  Sum2:=0;
  Yhat:=MatX*RegCoeff;
    Sum1:=Sum1+(Yhat(i,1)-YMean)^2;
    Sum2:=Sum2+(VectY(i,1)-YMean)^2;
  Rsqr:=Sum1/Sum2;
  // return the results
  RETURN {Rsqr,RegCoeff};
PolyReg
EXPORT PolyReg(DSMat,SelXCol,SelYCol,Order)
  LOCAL i,j,x,y;
  LOCAL lstDimX,NumRows;
  LOCAL MatX, VectY, RegCoeff;
  LOCAL YMean,Sum1,Sum2,Yhat,Rsqr;
  lstDimX:=SIZE(DSMat);
  NumRows:=lstDimX(1);
  // initialize matrix and vector
  MatX:=MAKEMAT(1,NumRows,Order+1);
  VectY:=MAKEMAT(1,NumRows,1);
  Sum1:=0;
  // populate matrix X and vector y with data
  FOR i FROM 1 TO NumRows DO
    y:=DSMat(i,SelYCol);
    x:=DSMat(i,SelXCol);
    VectY(i,1):=y;
    Sum1:=Sum1+y;
    FOR j FROM 1 TO Order DO
      MatX(i,j+1):=x^j;
  // calculate ymean
  YMean:=Sum1/NumRows;
  // calculate regression coefficients
  // calculate the sums of squares of
  // (yhat - ymean) and (y - ymean)
  Sum1:=0;
  Sum2:=0;
    Yhat:=RegCoeff(1,1);
      Yhat:=Yhat+RegCoeff(j+1,1)*x^j;
    Sum1:=Sum1+(Yhat-YMean)^2;
    Sum2:=Sum2+(y-YMean)^2;
  // calculate coefficient of determination
  Rsqr:=Sum1/Sum2;
PowerFit
EXPORT PowerFit(MatX,VectY)
  LOCAL i,j;
  LOCAL lstDimX,NumRowsX,NumColsX;
  LOCAL TMatX,TVectY,RegCoeff,Rsqr;
  LOCAL YMean,Sum1,Sum2,Yhat;
  // get the number of rows and columns of matrix MatX
  NumColsX:=lstDimX(2);
  // create matrices to store transformed data
  TMatX:=MAKEMAT(1,NumRowsX,NumColsX+1);
  TVectY:=MAKEMAT(1,NumRowsX,1);
    TVectY(i,1):=LN(VectY(i,1));
    FOR j FROM 1 TO NumColsX DO
      TMatX(i,j+1):=LN(MatX(i,j));
  RegCoeff:=LSQ(TMatX,TVectY);
  // calculate ymean
  Sum1:=0;
    Sum1:=Sum1+TVectY(i,1);
  Sum1:=0;
  Sum2:=0;
  Yhat:=TMatX*RegCoeff;
    Sum2:=Sum2+(TVectY(i,1)-YMean)^2;
  Rsqr:=Sum1/Sum2;
LinearizedReg
EXPORT LinearizedReg(DSMat,lstSelXData,lstSelYData)
  LOCAL i,x,y;
  LOCAL MatX,VectY,RegCoeff;
  LOCAL SelXCol,ShiftX,ScaleX,PowerX;
  LOCAL SelYCol,ShiftY,ScaleY,PowerY;
  LOCAL Sum1,Sum2,YMean,Yhat,Rsqr;
  // get parameters for x
  SelXCol:=lstSelXData(1);
  ShiftX:=lstSelXData(2);
  ScaleX:=lstSelXData(3);
  PowerX:=lstSelXData(4);
  // get parameters for y
  SelYCol:=lstSelYData(1);
  ShiftY:=lstSelYData(2);
  ScaleY:=lstSelYData(3);
  PowerY:=lstSelYData(4);
  // create regression matrix and vector
  MatX:=MAKEMAT(1,NumRowsX,2);
  // populate matrix and vector
    x:=ScaleX*DSMat(i,SelXCol)+ShiftX;
    y:=ScaleY*DSMat(i,SelYCol)+ShiftY;
    // transform x
    IF PowerX==0 THEN
      x:=LN(x);
    ELSE
      x:=x^PowerX;
    // transform y
    IF PowerY==0 THEN
      y:=LN(y);
    ELSE
      y:=y^PowerY;
    MatX(i,2):=x;
    VectY(i,1):=y;
  // calculate ymean
  Sum1:=0;
    y:=VectY(i,1);
    Sum1:=Sum1+y;
  Sum1:=0;
  Sum2:=0;
  Rsqr:=Sum1/Sum2;
LinearizedReg3
EXPORT LinearizedReg3(DSMat,lstSelXData,lstSelZData,lstSelYData)
  LOCAL i,x,y,z;
  LOCAL SelZCol,ShiftZ,ScaleZ,PowerZ;
  // get parameters for z
  SelZCol:=lstSelZData(1);
  ShiftZ:=lstSelZData(2);
  ScaleZ:=lstSelZData(3);
  PowerZ:=lstSelZData(4);
  MatX:=MAKEMAT(1,NumRowsX,3);
    z:=ScaleZ*DSMat(i,SelZCol)+ShiftZ;
    // transform x
    IF PowerX==0 THEN
      x:=LN(x);
    ELSE
      x:=x^PowerX;
    // transform z
    IF PowerZ==0 THEN
      z:=LN(z);
    ELSE
      z:=z^PowerZ;
    // transform y
    IF PowerY==0 THEN
      y:=LN(y);
    ELSE
      y:=y^PowerY;
    MatX(i,2):=x;
    MatX(i,3):=z;
    VectY(i,1):=y;
  // calculate ymean
  Sum1:=0;
    y:=VectY(i,1);
    Sum1:=Sum1+y;
  Sum1:=0;
  Sum2:=0;
  Rsqr:=Sum1/Sum2;
MLRX
EXPORT MLRX(DSMat,MaxTerms,TrnfMat)
  LOCAL i,j,x,Rsqr;
  LOCAL lstDimX,lstDimT,NumRowsX,NumColsX;
  LOCAL SelXCol,Shift,Scale,PowerX;
  LOCAL InsMat,InsCol,NumTrnf;
  // get the number of transformations
  lstDimT:=SIZE(TrnfMat);
  NumTrnf:=lstDimT(1);
  // create the data matrices
  MatX:=MAKEMAT(1,NumRowsX,MaxTerms+1);
  FOR j FROM 1 TO NumTrnf DO
    // get the transformation/insertion parameters
    SelXCol:=TrnfMat[j,1];
    Scale:=TrnfMat[j,2];
    Shift:=TrnfMat[j,3];
    PowerX:=TrnfMat[j,4];
    InsMat:=TrnfMat[j,5];
    InsCol:=TrnfMat[j,6];
    // process all rows for current variable selection,
    // transformation, and insertion
      // get x
      x:=DSMat[i,SelXCol];
      // transform x by scaling and shifting
      x:=Scale*x+Shift;
      // raise x to power or take ln() value
      IF PowerX==0 THEN
        x:=LN(x);
      ELSE
        x:=x^PowerX;
      // insert in targeted matrix
      IF InsMat>0 THEN
        // insert in matrix of independent variables
        IF InsCol>(MaxTerms+1) THEN
          // display an error message
          MSGBOX("Column "+InsCol+" is outside the range of columns");
          RETURN "ERROR";
        MatX[i,InsCol]:=MatX[i,InsCol]*x;
      ELSE
        // insert in vector of dependent variable
        VectY[i,1]:=VectY[i,1]*x;
  // calculate ymean
  Sum1:=0;
    Sum1:=Sum1+VectY(i,1);
  // calculate the correlation coefficient
  Sum1:=0;
  Sum2:=0;
  Rsqr:=Sum1/Sum2;
BestLR
EXPORT BestLR(Data,lstSel,lstX,lstY)
  LOCAL Tx,Ty,i,j,k;
  LOCAL SelXCol,SelYCol;
  LOCAL PowerX,PowerY;
  LOCAL MatX,VectY,RegCoeff,MatRes;
  LOCAL lstDim,NumRows,ResUpdated;
  LOCAL Sum1,Sum2,Rsqr,YMean,Yhat;
  LOCAL MaxRes,NumColRes;
  // use the default transformation list
  // for variable x if lstX is empty
  IF SIZE(lstX)==0 THEN
    lstX:={-3,-2,-1,-0.5,0,0.5,1,2,3};
  // for variable y if lstY is empty
  IF SIZE(lstY)==0 THEN
    lstY:={-3,-2,-1,-0.5,0,0.5,1,2,3};
  // set the maximum number of results
  MaxRes:=20;
  // set the number of columns in
  // the results matrix
  NumColRes:=5;
  // get the indices for variable x and y
  SelXCol:=lstSel(1);
  SelYCol:=lstSel(2);
  // get the number of rows of data
  lstDim:=SIZE(Data);
  NumRows:=lstDim(1);
  // create the result and regression matrices
  MatX:=MAKEMAT(1,NumRows,2);
  MatRes:=    MAKEMAT(0,MaxRes,NumColRes);
  // iterate for each transformation in x
  FOR Tx FROM 1 TO SIZE(lstX) DO
    // get the current power of x
    PowerX:=lstX(Tx);
    // transform x
    IF PowerX==0 THEN
        MatX(i,2):=LN(Data(i,SelXCol));
    ELSE
        MatX(i,2):=Data(i,SelXCol)^PowerX;
    // iterate for each transformation in y
    FOR Ty FROM 1 TO SIZE(lstY) DO
      // get the current power of y
      PowerY:=lstY(Ty);
      // transform y
      IF PowerY==0 THEN
          VectY(i,1):=LN(Data(i,SelYCol));
      ELSE
          VectY(i,1):=Data(i,SelYCol)^PowerY;
      // calculate ymean
      Sum1:= 0;
      Sum1:=0;
      Sum2:=0;
      Rsqr:=Sum1/Sum2;
      // Rsqr is better than last entry
      // in the results matrix?
      IF Rsqr>MatRes(MaxRes,1) THEN
        ResUpdated:=0;
        // loop for each row in the
        // results matrix
        FOR i FROM 1 TO MaxRes DO
          // compare with other Rsqr values
          IF ResUpdated==0 AND Rsqr>MatRes(i,1) THEN
            // found better Rsqr for row i
            // push rows below?
            IF i<MaxRes THEN
              j:=MaxRes-1;
              REPEAT
              // FOR j FROM MaxRes-1 TO n STEP -1 DO
                FOR k FROM 1 TO NumColRes DO
                  MatRes(j+1,k):=MatRes(j,k);
                j:=j-1;
                //END;
              UNTIL j<i;
            // store new best results
            MatRes(i,1):=Rsqr;
            MatRes(i,2):=PowerY;
            MatRes(i,3):=PowerX;
            MatRes(i,4):=RegCoeff(1,1);
            MatRes(i,5):=RegCoeff(2,1);
            ResUpdated:=1;
    END; // FOR Ty
  END; // FOR Tx
  RETURN MatRes;
BestMLR2
EXPORT BestMLR2(Data,lstSel,lstX,lstZ,lstY)
  LOCAL Tx,Tz,Ty,i,j,k;
  LOCAL SelXCol,SelZCol,SelYCol;
  LOCAL PowerX,PowerZ,PowerY;
  // use default transformation list
  // if lstX is an empty list
  // if lstZ is an empty list
  IF SIZE(lstZ)==0 THEN
    lstZ:={-3,-2,-1,-0.5,0,0.5,1,2,3};
  // if lstY is an empty list
  // Set the number of rows and columns in the results matrix
  MaxRes:=20;
  NumColRes:=7;
  // get the variable selectors
  SelXCol:=lstSel(1);
  SelZCol:=lstSel(2);
  SelYCol:=lstSel(3);
  // get the number of rows in matrix Data
  lstDim:=SIZE(Data);
  NumRows:=lstDim(1);
  // create the regression and results matrices
  MatX:=MAKEMAT(1,NumRows,3);
  MatRes:=MAKEMAT(0,MaxRes,NumColRes);
  // start the calculations
  // process transformations for variable x
    PowerX:=lstX(Tx);
    // transform x
    IF PowerX==0 THEN
    ELSE
    // process transformations for variable z
    FOR Tz FROM 1 TO SIZE(lstZ) DO
      PowerZ:=lstZ(Tz);
      // transform z
      IF PowerZ==0 THEN
          MatX(i,3):=LN(Data(i,SelZCol));
      ELSE
          MatX(i,3):=Data(i,SelZCol)^PowerZ;
      // process transformations for variable y
        PowerY:=lstY(Ty);
        // transform y
        IF PowerY==0 THEN
        ELSE
        // calculate ymean
        Sum1:=0;
        Ymean:=Sum1/NumRows;
        Sum1:=0;
        Sum2:=0;
          Sum1:=Sum1+(Yhat(i,1)-Ymean)^2;
          Sum2:=Sum2+(VectY(i,1)-Ymean)^2;
        Rsqr:=Sum1/Sum2;
          ResUpdated:=0;
          // check which row to insert better
          // regression results
            // insert new results in row i?
              // inserting inside the results matrix?
              IF i<MaxRes THEN
                // downward copy rows from MaxRes-1 to i
                j:=MaxRes-1;
                REPEAT
                  j:=j-1;
                UNTIL j<i;
              // insert better results in row i
              MatRes(i,1):=Rsqr;
              MatRes(i,4):=PowerZ;
              FOR k FROM 1 TO 3 DO
                MatRes(i,4+k):=RegCoeff(k,1);
              ResUpdated:=1;
      END; // FOR Ty
    END; // FOR Tz
  END; // FOR Tx
  RETURN MatRes;
BestPolyReg
EXPORT BestPolyReg(Data,SelXCol,SelYCol,MinOrder,MaxOrder)
  LOCAL i,k,x,y,Order;
  LOCAL MatX,VectY;
  LOCAL lstDim,NumRows;
  LOCAL Sum1,Sum2,Sum3,AICc,BestAICc;
  LOCAL Rsqr,RsqrAdj,YMean,Yhat,RegCoeff;
  LOCAL BestOrder,BestRsqr,BestRsqrAdj,BestRegCoeff;
  lstDim:=SIZE(Data);
  NumRows:=lstDim(1);
  IF MinOrder<1 THEN
    MinOrder:=1;
  // initialize best regression data
  BestOrder=0;
  BestRsqr:=0;
  BestRsqrAdj=0;
  BestAICc:=1E499;
  // initialize vector y
  // calculate ymean … needs to be done once!
  Sum1:=0;
    y:=Data(i,SelYCol);
    VectY(i,1):=y;
    Sum1:=Sum1+y;
  // calculate sum of y – ymean squared
  Sum2:=0;
    y:=Data(i,SelYCol);
  // iterate for the specified range of polynomial orders
  FOR Order FROM MinOrder TO MaxOrder DO
    // (re)create the matrix MatX
    MatX:=MAKEMAT(1,NumRows,1+Order);
    // fill the columns to to Order+1 with x^power values
      x:=Data(i,SelXCol);
      FOR k FROM 1 TO Order DO
        MatX(i,k+1):=x^k;
    Sum1:=0;
    Sum3:=0;
      Sum3:=Sum3+(VectY(i,1)-Yhat(i,1))^2;
    Rsqr:=Sum1/Sum2;
    // calculate the adjusted coefficient of determination
    RsqrAdj:=1-(1-Rsqr)*(NumRows-1)/(NumRows-Order-1);
    k:=Order+1;
    // if Sum3 is 0 then adjust it to a small value
    // to avoid getting a LN(0) error
    IF Sum3==0 THEN
      Sum3:=1E-499;
    // calculate AICc statistic
    AICc:=NumRows*LN(Sum3/NumRows)+2*k+(2*k*(k+1))/(NumRows-k-1);
    // display intermediate results
    PRINT("Order="+Order+", AICc="+AICc+", Sum3="+Sum3);
    // found a better fit?
    IF AICc<BestAICc THEN
      // update best regression data
      BestOrder:=Order;
      BestRsqr:=Rsqr;
      BestRsqrAdj:=RsqrAdj;
      BestAICc:=AICc;
      BestRegCoeff:=RegCoeff;
  RETURN {BestOrder,BestRsqr,BestRsqrAdj,BestAICc,BestRegCoeff};
BestMLR3
EXPORT BestMLR3(Data,lstSel,lstX,lstZ,lstT,lstY)
  LOCAL Tx,Tz,Ty,Tt,i,j,k;
  LOCAL SelXCol,SelZCol,SelTCol,SelYCol;
  LOCAL PowerX,PowerZ,PowerT,PowerY;
  // if lstT is an empty list
  IF SIZE(lstT)==0 THEN
    lstT:={-3,-2,-1,-0.5,0,0.5,1,2,3};
  MaxRes:=20;
  NumColRes:=9;
  SelXCol:=lstSel(1);
  SelZCol:=lstSel(2);
  SelTCol:=lstSel(3);
  SelYCol:=lstSel(4);
  lstDim:=SIZE(Data);
  NumRows:=lstDim(1);
    PowerX:=lstX(Tx);
    // transform x
    IF PowerX==0 THEN
    ELSE
      PowerZ:=lstZ(Tz);
      // transform z
      IF PowerZ==0 THEN
      ELSE
      // process transformations for variable t
      FOR Tt FROM 1 TO SIZE(lstT) DO
        PowerT:=lstT(Tt);
        // transform t
        IF PowerT==0 THEN
            MatX(i,4):=LN(Data(i,SelTCol));
        ELSE
            MatX(i,4):=Data(i,SelTCol)^PowerT;
          PowerY:=lstY(Ty);
          // transform y
          IF PowerY==0 THEN
          ELSE
          // calculate ymean
          Sum1:=0;
          Sum1:=0;
          Sum2:=0;
          Rsqr:=Sum1/Sum2;
            ResUpdated:=0;
                IF i<MaxRes THEN
                  j:=MaxRes-1;
                  REPEAT
                    j:=j-1;
                  UNTIL j<i;
                MatRes(i,1):=Rsqr;
                MatRes(i,5):=PowerT;
                FOR k FROM 1 TO 4 DO
                  MatRes(i,5+k):=RegCoeff(k,1);
                ResUpdated:=1;
        END; // FOR Ty
      END; // FOR Tt
    END; // FOR Tz
  END; // FOR Tx
  RETURN MatRes;
RErMLR2
EXPORT RErMLR2(MatX,VectY)
  LOCAL i,j,y,Rsqr;
  LOCAL lstDimX,NumRows,NumCols;
  LOCAL TMatX,VectOnes,RegCoeff;
  // calculate the number of observations and variables
  NumCols:=lstDimX(2);
  // create transformation matrices
  TMatX:=MAKEMAT(1,NumRows,NumCols+1);
  VectOnes:=MAKEMAT(1,NumRows,1);
    y:=VectY(i,1);
    TMatX(i,1):=1/y;
    FOR j FROM 1 TO NumCols DO
      TMatX(i,j+1):=MatX(i,j)/y;
  RegCoeff:=LSQ(TMatX,VectOnes);
  // calculate ymean
  Sum1:=0;
    y:=VectY(i,1);
    Sum1:=Sum1+y;
  Sum1:=0;
  Sum2:=0;
    y:=VectY(i,1);
      Yhat:=Yhat+RegCoeff(j+1,1)*MatX(i,j);
    Sum1:=Sum1+((Yhat-YMean)/y)^2;
    Sum2:=Sum2+((y-YMean)/y)^2;
  Rsqr:=Sum1/Sum2;
  // return the results as a list
RErPolyReg
EXPORT RErPolyReg(DSMat,SelXCol,SelYCol,Order)
  LOCAL i,j,x,y;
  LOCAL MatX,VectOnes,RegCoeff;
  // create the regression matrices
  // populate the regression matrices
    MatX(i,1):=1/y;
      MatX(i,j+1):=(x^j)/y;
  RegCoeff:=LSQ(MatX,VectOnes);
  // calculate ymean
  Sum1:=0;
    Sum1:=Sum1+DSMat(i,SelYCol);
  Sum1:=0;
  Sum2:=0;
  Rsqr:=Sum1/Sum2;
  // return the list of results
RErPowerFit
EXPORT RErPowerFit(MatX,VectY)
  LOCAL i,j,y,LnY;
  LOCAL TMatX,VectOnes,RegCoeff,Rsqr;
  Sum1:=0;
    LnY:=LN(VectY(i,1));
    Sum1:=Sum1+LnY;
    TMatX(i,1):=1/LnY;
      TMatX(i,j+1):=LN(MatX(i,j))/LnY;
  // calculate mean ln(y)
  Sum1:=0;
  Sum2:=0;
      Yhat:=Yhat+RegCoeff(j+1,1)*LN(MatX(i,j));
    y:=LN(VectY(i,1));
  Rsqr:=Sum1/Sum2;
Attached File(s)
.pdf  HP_Calculator_eNL_01_Jan_2013_v2.pdf (Size: 2.08 MB / Downloads: 192)
09-04-2014, 03:57 PM
Good info, thanks for sharing!
A quick and dirty linear regression can always be set up with LSQ, but the programs are helpful as they also contain regression diagnostics.
Is there a repository for other HP 39gII programs?
09-04-2014, 07:24 PM
(09-04-2014 03:57 PM)Helge Gabert Wrote:  Is there a repository for other HP 39gII programs?
Not specifically for the HP 39gII. It would be in the general area. I will copy my reply to the general area.
03-08-2015, 04:21 PM
my first draft for ANOVA with Prime is here.
03-24-2015, 07:48 PM
(09-04-2014 03:28 PM)Namir Wrote:  BestMLR2
        // calculate ymean
        Sum1:=0;
        Sum1:=0;
        Sum2:=0;
hi Namir,
in BestMLR2 there is a little typo: YMean and Ymean; to correct it I simply change the namevar in Local definition...
However is a very useful program!
All the suite of these programs should be inside the FW of Prime, perhaps with other programs to analyze multiple regression, thank you to have done them!
Salvo
