HP-19C
11-06-2023, 03:44 AM
HP-19C
Look what I found cheap :-)
Not working, but you never know, I haven't powered it up yet, just opened it. Some minor corrosion, print motor works, but I think there is a dead pixel in the print head, if I'm lucky it will be corrosion as well. I'll strip it down, clean it up, replace some caps and see if luck is on my side. cheers Tony |
11-06-2023, 05:13 AM
RE: HP-19C
Good luck you get it working Tony
11-07-2023, 07:30 PM
RE: HP-19C
What's cheap?
11-07-2023, 09:13 PM
RE: HP-19C
(11-07-2023 07:30 PM)Siegfried Wrote: What's cheap? An amount less than he thought he would have had to pay. Everyone places different values on how much things are worth... Tony probably would have put a number there if he intended to share a number. --Bob Prosperi |
11-07-2023, 09:35 PM
(This post was last modified: 11-07-2023 09:36 PM by teenix.)
RE: HP-19C
Sorry guys, my thoughts were stuck on the 19C, I didn't even think about the price.
It was about $US110. From what I have seen that seems good. I know it was sold not working but I'm sure one way or another it will come back to life. I tested the keyboard and display with my 19C CPU replacement and it all works ok. cheers Tony |
