(19C/29C) Solving second-degree equations
11-10-2023, 06:25 PM
Here's just a little program for HP-19C/HP-29C which, starting from a second-degree equation, calculates exclusively in the stack :
- the discriminant Δ ; - the successive X and Y coordinates of the extremum ; - the real solution(s) if the discriminant is positive or zero; - the real and imaginary solutions if the discriminant is negative. To do this, enter the parameters a, b and c in Z, Y and X in the stack, then run the program using [GSB] [4]. For example, for the equation -x² + x + 1 = 0: [1] [CHS] [ENTER] [CHS] [ENTER] [GSB] [4]; the calculator then displays Δ = 5, X=0.5, Y=1.25, x1≈1.618 and x2≈-0.618. For the equation x² + 2x + 3 = 0: [1] [ENTER] [2] [ENTER] [3] [GSB] [4]; then the calculator displays Δ = -8, X=-1, Y=2, the real part u=-1 and successively the two imaginary parts v1≈1.414 and v2≈-1.414. ![]() ![]() ![]() Naturally, the program also works on the HP-29E calculator (where it was created). |
