hp prime
11-16-2023, 11:17 PM
hp prime
is it possible to put images onto the hp prime ?
11-17-2023, 05:55 AM
RE: hp prime
Bonjour
Oui, c'est possible de charger des images au format 'JPG' ou 'PNG'.
La façon la plus simple est de charger celles-ci depuis le logiciel de connectivité
dans le dossier 'Fichiers' d'une application.
Hello
Yes, it is possible to upload images in 'JPG' or 'PNG' format.
The easiest way is to load them from the connectivity software
in the 'Files' folder of an application.
Sorry for my english
11-17-2023, 07:02 AM
RE: hp prime
There is also the ICON command (image definition in the program source code as a hexadecimal string), which is a bit outdated but some people still use it. However, the solution proposed by Tyann is definitely better.
