high-resolution photo request - Spice display test
11-21-2023, 06:43 AM
I don't have a real Spice series calculator (31E, 32E, 33E, 33C, 34C, 37E, 38E, 38C) at hand. If anyone does, and can take a high-resolution photo of the calculator showing the self-test display (resulting from "STO ENTER", -8,8,8,8,8,8,8,8,8,8,), that would be useful to me for Nonpareil 2, to make the display appearance more accurate.
Ideally a photo would be done with the display, top, left, and right sides of calculator, and top row of keys visible, but with the display as large as possible given those constraints. Taking the phote on a darkened room or with only subdued lighting may be best. It's possible that a "nighttime" setting of a camera might give a better result than default mode. I'm hoping to avoid having much flare or blurring of the display digits. Not that a fast shutter speed might not capture the entire display, since it is time-multiplexed. Thanks! |
11-21-2023, 05:05 PM
RE: high-resolution photo request - Spice display test
Sent you 2 photos I took to your mailbox from the HP calculator chips website.
Andi |
11-21-2023, 06:58 PM
Andi sent me excellent photos, better than I'd dared to hope!
Thank you! |
