EZDraw a simple 2D graphical programming environment
12-15-2023, 01:09 AM
EZDraw is a simple 2D graphical programming environment, based on the HTML5 canvas. It allows you to make simple drawings and animations with very little code.
Reference commands
https://davidprograma.github.io/ezdraw/v1/reference/
sample: Multi-body orbit:
online execution
PHP Code:
function init(system) {
let lim 1.5;
xlimits(-limlim);    // horiz limits for drawing
ylimits(-limlim);    //  vert limits for drawing
let sun = new Body();  // 'Sun'
sun.color "#FE4";    // color
sun.0.05;          // radius
    // using defaults for other sun parameters
let mars = new Body(); // 'Mars' body
mars.px 1;           // initial position, x component
mars.vy 0.85;         // initial position, y component
mars.0.02;         // radius
mars.0.000001;     // mass
mars.color "#951";   // color
system.add(sun);               // add Sun to system
system.add(mars);              // add Mars to system
class
Body {
constructor() {
this.px this.py 0// position
this.vx this.vy 0// velocity
this.ax this.ay 0// acceleration
this.1;            // mass
this.0.1;          // radius
this.color 'white';  // color
update(dt) {
this.vx += this.ax dt;  // acceleration affects...
this.vy += this.ay dt;  // ...velocity;
this.px += this.vx dt;  // velocity affects...
this.py += this.vy dt;  // ...position
draw() {
linecolor(null);                  // no line
fillcolor(this.color);            // fill color
circle(this.pxthis.pythis.r); // circle
class
BodySystem {
constructor() {
this.bodies = [];  // array of bodies
this.1;        // gravitation constant
add(body) {
this.bodies.push(body); // add body to array
update(dt) {
// set all accelerations to zero
for (let i 0this.bodies.lengthi++)
this.bodies[i].ax this.bodies[i].ay 0;
// calculate accelerations for pairs of bodies
            for (
let j i+1this.bodies.lengthj++)
this.calcAcc(this.bodies[i], this.bodies[j]);
// update velocities and positions for all bodies
this.bodies[i].update(dt);
calcAcc(body1body2) {
let dx body2.px body1.px// distance x component
let dy body2.py body1.py// distance y component
let d2 dx dx dy dy;   // squared distance
let d Math.sqrt(d2);        // distance
let ux dx d;              // unitary vector, x comp
let uy dy d;              // unitary vector
let a1 this.body2.d2// scalar acc, body 1
let a2 this.body1.d2// scalar acc, body 2
body1.ax += ux a1;  // body 1 acc, x component
body1.ay += uy a1;  // body 1 acc, y component
body2.ax += -ux a2// body 2 acc, x component
body2.ay += -uy a2// body 2 acc, y component
draw() {
        for (
this.bodies[i].draw();
let system = new BodySystem(); // Body System
init(system);
function
draw() {               // draw function for ezdraw
clear('black');             // paint it black
system.draw();              // draw body system
system.update(deltatime()); // update positions in body system
redraw();                   // request redraw
