Sharing good replacement for HP 15C rubber feet
12-15-2023, 11:39 AM
(This post was last modified: 12-15-2023 11:48 AM by wmundstock.)
Hi All,
I've discovered a commercial product that serves as an ideal replacement for lost or worn rubber feet on HP 15/12 models. It's a 3M tape that you can easily cut and apply. While it doesn't feel exactly like the original 15Cs, it closely matches the feel of the HP 15C Collector Edition. You can find it on AliExpress for a very low cost. Here's the link:AliExpress 3M Tape This, to me, seems like the perfect solution, and it's really affordable. I wanted to share this in case anyone else is in search of a similar product. |
12-15-2023, 09:11 PM
RE: Sharing good replacement for HP 15C rubber feet
Need to get this added to the HP Calculator Parts & Services article.
12-16-2023, 09:32 PM
(12-15-2023 11:39 AM)wmundstock Wrote: You can find it on AliExpress for a very low cost. Here's the link:AliExpress 3M Tape Nice! Which thickness did you order? When I open the link it selects the first variant (300 mm x 10 mm, 0.5 mm thickness) - not sure if this is deliberate or coincident? |
