Using SolveSys to solve equation with variable using unit
01-09-2024, 10:29 AM
Sorry if it's a duplicate or already solved but I don't find ...
how can I use solvesys (on hp prime) to solve system with variable using units:
i.e.:
distance=time*velocity
distance in nmi, time in hour and velocity in knot
I know I can remove unit and it's done.
but if the velocity is in m/s, I must convert it before or adding a factor in equation.
I come from hp48 and on this one it's easy.
Can you help me ?
04-11-2024, 05:58 PM
RE: Using SolveSys to solve equation with variable using unit
I’m not sure if this is what you’re looking for, but you can solve in CAS:
solve(10_nmi=5_h*x,x)
Returns
[2_nmi/h]
You can use USIMPLIFY if you get a mix of units like m*s/s -> m, and MKSA to go from nmi/h to meter-kilogram-second-ampere system.
