Lambert function and Wolfram or "±infinity+i×K=±infinity" ?
01-16-2024, 12:06 PM
(This post was last modified: 01-16-2024 12:08 PM by Gil.)
For my HP50G LambertW program, I was making comparisons with Wolfram Alpha.
In Wolfram Alpha: LambertW(-100)=3.2+2.5i LambertW(-100)=3.2+2.7i LambertW(-1E6)=11.4+2.9i LambertW(-1E9)=17. 8+2.98i LambertW(-1E15)=31.1+3.04i LambertW(-1E30)=64.9+3.09i LambertW(-1E30000)=69066.4+3.1415i LambertW(-1E3000000000)=6.9E9 +3.141592653i ... Two observations, as real x tends to go to very large negative values : 1) we see that the real part (of LambertW0) seems to —> +infinity; 2) we see that the imaginary part (of LambertW0) seems to —> pi. My questions If 2) is true, it means that lim IM(W0) =pi≠0, when x —> -infinity. Then, can we say, considering the above, that lim W0(-infinity) = -infinity, as does write Wolfram Alpha, leaving out the imaginar part? Or W0(-infinity) = -infinity+pi*i... = -infinity? Or, more generally: if lim "A" = C, when x-> B, & C=±infinity +i×(constant K), can we say that the limit C=±infinity, leaving out the imaginary part (the constant K) (the latter, K, being "peanuts" relatively to the ± infinity of the real part)? I thank you in advance for your comments. Gil |
01-16-2024, 02:01 PM
(This post was last modified: 01-16-2024 02:13 PM by Gil.)
RE: Lambert function and Wolfram or "±infinity+i×K=±infinity" ?
With Wolfram Alpha
LambertW (k=any value, z=(any real value ±i*infinity) = infinity. Now it seems that lim LambertW, k free, for z=a+ib & with a=±infinity, b=±infinity, gives equally infinity. Could anyone, if possible a "math guy", confirm it? My questions are related of course to HP programs, as I want to implement an output in my Lambert HP50G function for any real or complex "numbers, including the ± infinity input cases, the outputs of which I wish to treat as follows : Wk=0±1...(oo+ib): 'oo' Wk=0±1...(a+ioo): 'oo' Wk=0±1...(±oo±ioo): 'oo' with oo being the infinity sign. Thanks again for your insight. |
01-16-2024, 03:40 PM
Wolfram Alpha
LambertW (-infinity) = (infinity) But (infinity) * EXP (infinity) can't be equal to -infinity Can Wolfram Alpha be wrong? |
01-16-2024, 05:16 PM
(This post was last modified: 01-16-2024 05:26 PM by Nigel (UK).)
(01-16-2024 03:40 PM)Gil Wrote: Wolfram Alpha Not in this case (although in general I’m sure it can be!). \(\exp(+\infty+{\rm i}\pi)\) is indeed \(-\infty\) because \(\exp({\rm i}\pi)=-1\). So far as I can see you’ve already said something like this a couple of posts ago, so maybe I’m not understanding what you are asking? Nigel (UK) |
01-16-2024, 06:11 PM
As I said,
LambertW (0,-infinity) = (infinity) with Wolfram Alpha. I think it is impossible, as the (given answer -= infinity) * EXP (given answer =infinity) can't be equal to -infinity Can Wolfram Alpha be wrong? Instead, the answer seems rather to be (infinity+i*pi). Then (infinity+i*pi) × exp(infinity) × cos (pi) = Infinity × -1= -infinity. But infinity + i*pi = infinity + number = infinity... In a way, Wolfram may correct. Question, what most "reasonable" output should I give for W0(-infinity), W0(±i×infinity), W0(±infinity±i×infinity)? |
01-16-2024, 07:36 PM
(01-16-2024 06:11 PM)Gil Wrote: Instead, the answer seems rather to be (infinity+i*pi). (∞ + pi*I) * -∞ = -∞ - ∞*I Still does not get back -∞, unless ... (∞ + pi*I) = ∞ ? (∞ + pi*I) * -∞ = ∞ * -∞ = -∞ But then, we are just picking and choosing! We start with saying W(-∞) = ∞ + pi*I ≠ ∞ But to make it roundtrip, we had to simplify (∞ + pi*I) = ∞ We may turn it around, and say ∞ = ∞ + (any finite number, real or complex) ∞ * e^∞ = ∞ * e^(∞+θ*i) = ∞ * e^∞ * cis(θ) = ∞ * cis(θ) --> W(∞ * cis(θ)) = ∞ // infinity is weird! |
01-16-2024, 09:34 PM
(This post was last modified: 01-16-2024 09:36 PM by Gil.)
Nice summarised presentation, Albert.
For me, the answer given by Wolfram is misleading, as we requested W0(-1) and its "answer is infinity", but "answer is infinity" ×EXP("answer is infinity") clearly cannot give back -1, unless we assume that, in one step, infinity+iPI≠ infinity to assume at the end that infinity+iPI=infinity, which is contradictory. What would you think if, for such cases, Wolfram Alpha would reply here "undefined", for x—> -oo, but curiously also for x—>+oo? Indeed, x—> +oo = +oo + "Somewhat", in particular, oo+ipI, and, as we saw, (x+ipI) × EXP(x+iPI) might give, with Euler and cos PI = - 1, a result of -oo (by special "picking up"), though clearly the graphs shows the "right" answer having rather to be +oo. |
01-16-2024, 09:53 PM
I read your last post again, Albert, and think that is a similar reasoning that might have incited the Wolfram team to give a possible math answer for W(-oo)=W(+oo) = +oo.
01-16-2024, 11:45 PM
(This post was last modified: 01-17-2024 12:13 AM by Albert Chan.)
Not all math software follow Wolfram Alpha's logic.
p2> from mpmath import * p2> mp.pretty = 1 p2> z = -inf p2> lambertw(z), log(z) ((+inf + 3.14159265358979j), (+inf + 3.14159265358979j)) p2> z = mpc(0,inf) p2> lambertw(z), log(z) ((+inf + 1.5707963267949j), (+inf + 1.5707963267949j)) p2> z = inf p2> lambertw(z), log(z) (+inf, +inf) I am OK with ∞ + 1 = ∞, but not so much for ∞ + i = ∞ I like mpmath style better. p2> inf + 1 +inf p2> inf + j (+inf + 1.0j) |
01-17-2024, 12:36 AM
(This post was last modified: 01-17-2024 01:02 AM by Gil.)
Yes, W0(-inf) = inf+i×pi is the limit that appears when x tends to very large negative real numbers.
But, again, (inf+i×pi)*EXP(inf+i×pi) (1) =(inf+i×pi)*EXP(inf) *EXP(i×pi) =(inf+i×pi)*inf*(cos pi +i× sin pi) =(inf+i×pi)*inf*(-1) =(inf+i×inf)*(-1) =-inf-i*inf ≠ -inf if I am not mistaken, unless you force and say that first member in (1), inf+i×PI, = inf, with no more imaginary part (but that sounds strange : infinity of bananas [real part of number] + 1 orange×[imaginary part] =? infinity of bananas; on the other hand, infinity of bananas means that there are everywhere bananas in the universe, and consequently no place for a single orange). And then annoying again, mixing up the definitions. By the way, what does give your software for W0(infinity +10i). By what I understood, the output should be infinity + 10i, vs inf with Wolfram. |
01-17-2024, 12:57 AM
But, again, (inf+i×pi)*EXP(inf+i×pi) (1) =(inf+i×pi)*EXP(inf) *EXP(i×pi) =(inf+i×pi)*inf*(cos pi +i× sin pi) =(inf+i×pi)*inf*(-1) =(inf+i×inf)*(-1) =-inf-i*inf ≠ -inf if I am not mistaken, unless you force and say that first member in (1), inf+i×PI, = inf, with no more imaginary part (but that sounds strange : infinity of bananas [real part of number] + 1 orange×[imaginary part] =? infinity of bananas; on the other hand, infinity of bananas means that there are everywhere bananas in the universe, and consequently no place for a single orange). And then annoying again, mixing up the definitions. |
01-17-2024, 02:06 AM
(This post was last modified: 01-17-2024 10:43 PM by Albert Chan.)
Update with generalized W formula. Set θ=pi, we have W0(-∞) = ∞ + pi*I
Let z = ∞*cis(θ), r = ln(|z|) We want to show w = W0(z) = ln(z) = r + θ*I By checking for round-trip, i.e. w * e^w = z w = r + θ*I ≈ r * cis(θ/r) // polar form e^w = e^(r + θ*I) = e^r * cis(θ) w * e^w ≈ r*e^r * cis(θ/r + θ) |z| → ∞ --> r → ∞ too w * e^w = ∞ * cis(0 + θ) = z From definition of k-th branch of W k = (w + ln(w) - ln(z)) / (2*pi*i) 2*pi*k = im(w + ln(w) - ln(z)) = θ + atan(θ/r) - θ = 0 --> k = 0 --> W0(∞*cis(θ)) = ln(∞*cis(θ)) = ∞ + θ*I Again, from definition of k-th branch: --> Wk(∞*cis(θ)) = ln(∞*cis(θ)) + 2*k*pi*I |
01-17-2024, 11:34 AM
(This post was last modified: 01-17-2024 11:42 AM by Gil.)
"w = r + pi*I ≈ r * cis(pi/r) // polar form
e^w = e^(r*cos(pi/r)) * cis(r*sin(pi/r)) w * e^w = r*e^(r*cos(pi/r)) * cis(pi/r + r*sin(pi/r))" How to you go from line 2 to 3 w = r * cis(pi/r) w= r * cos (pi/r) + I*r*sin(pi/r) e^w = e^(r*cos(pi/r)) * e^(I*r*sin(pi/r)) =e^(r*cos(pi/r)) * cis(r*sin(pi/r)) With w≈ r * cis(pi/r) w*e^w=r * cis(pi/r) × e^(r*cos(pi/r)) * cis(r*sin(pi/r)) =? r*e^(r*cos(pi/r)) * cis(pi/r + r*sin(pi/r)) cis (A)* cis (B) =? +cis (A+B) |
01-17-2024, 12:04 PM
(This post was last modified: 01-17-2024 12:05 PM by Gil.)
I am not so familiar with this notation.
I discovered it thanks you, Albert. And checked that cis (A+B) = cis A × cis B. By the way, with your software, may I kindly ask you if it were possible to check, for Wk=0, Wk=±1, Wk=±2, W±3 and arguments x = ± infinity +i*20, 20±I*inf and ±inf±I×inf, the given outputs of Wk(x)? Thanks again for your painstaking. Your insights are always most previous, for me and, certainly, beyond the HP community. |
01-17-2024, 01:51 PM
Some "guessed" results for input z =a+ib, with a = -INF:
W-3(-INF +i20) = inf-i(5pi) W-3(-INF - i20) = inf-i(7pi) W-2(-INF +i20) = inf-i(3pi) W-2(-INF - i20) = inf-i(5pi) W-1(-INF +i20) = inf-i(pi) W-1(-INF - i20) = inf-i(3pi) W0(-INF +i20) = inf+i(pi) W0(-INF - i20) = inf-i(pi) W1(-INF + i20) = inf+i(5pi) W1(-INF - i20) = inf+i(3pi) W2(-INF + i20) = inf+i(5pi) W2(-INF - i20) = inf+i(pi) W3(-INF + i20) = inf+i(7pi) W3(-INF - i20) = inf+i(5pi) Wk(-INF, +ib, b>0) = inf+i(2k+1)(pi) Wk(-INF, +ib, b<0) = inf+i(2k+1-2)(pi) Wk(-INF, +ib, b>0) = inf+i(2k+1)(pi) Wk(-INF, +ib, b<0) = inf+i(2k-1)(pi) Conclusion Wk(-INF, +ib, b≠0) = inf+i(2k+sign(b))(pi) & we may check Wk(-INF, +ib, b=0) = inf+i(2k+1)(pi) Summary Wk(-INF, +ib) =inf+i(pi) *(2k+1, if b>=0; 2k-1, if b<0) |
01-17-2024, 02:01 PM
01-17-2024, 02:39 PM
(This post was last modified: 01-18-2024 12:11 AM by Gil.)
Now Wk(inf +ib)
W-3(INF +i20) = inf-i(6pi) W-3(INF - i20) = inf-i(6pi) W-3(-INF - i20) = inf-i(5pi) W-3(-INF + i20) = inf-i(7pi) W-3(-INF - i0) = inf-i(5pi) W-2(INF +i20) = inf-i(4pi) W-2(INF - i20) = inf-i(4pi) W-1(INF +i20) = inf-i(2pi) W-1(INF - i20) = inf-i(2pi) W0(INF +i20) = inf-i(0pi) W0(INF - i20) = inf-i(0pi) W1(INF +i20) = inf+i(2pi) W1(INF - i20) = inf+i(2pi) W2(INF +i20) = inf+i(4pi) W2(INF - i20) = inf+i(4pi) W2(INF +i0) = inf+i(4pi) Conclusion & summary for Wk(inf+ib) Wk(INF +ib) = inf+2ik z=a+ib, a=±infinity, b≠±infinity Wk(±infinity+ib) =+inf + i × (2k, if a>0; (else 2k+1, if b>=0; 2k-1, else)) |
01-17-2024, 02:44 PM
That seems to make sense and should be acceptable for my HP50G result.
01-17-2024, 03:07 PM
(This post was last modified: 01-17-2024 03:40 PM by Gil.)
From previous post:
A) z=a+ib, a=±infinity, b≠±infinity Wk(±infinity+ib) =+inf + i × (2k, if a>0; (else 2k+1, if b>=0; 2k-1, else)) And to complete Cases z=a≠±inf + i*INF, i*(-INF) W-3(20, i*INF) = inf - i(5.5pi) W-3(20, -i*INF) = inf - i(6.5pi) W-2(20, i*INF) = inf - i(3.5pi) W-2(20, -i*INF) = inf - i(4.5pi) W-1(20, i*INF) = inf - i(1.5pi) W-1(20, -i*INF) = inf - i(2.5pi) W0(20, i*INF) = inf +i(0.5pi) W0(20, -i*INF) = inf - i(0.5pi) W1(20, i*INF) = inf +i(2.5pi) W1(20, -i*INF) = inf+i(1.5pi) B) Wk(a+ib,a≠±infinity, b=±in) = inf+i×(2k+0.5, if b>0 ; 2k-0.5, else) Cases z=a+ib, a=±inf, b=±inf W-3(inf, i×inf) = inf - i(6pi) W-3(inf, -i×inf) =inf - i(6pi) W-3(-inf, i×inf) = inf - i(5pi) W-3(-inf, -i×inf) =inf - i(7pi) C) Conclusion Wk(a=+inf, b=±inf) = inf + i(2k) Wk(a=-inf) = inf +i(2k+1, if b=inf; 2k-1, if b=-inf) Summary of A & C Wk(a=+inf, b=free) = inf + i(2k) Wk(a=-inf) = inf +i(2k+1, if b>≠0; 2k-1, else And case B repeated B) Wk(a+ib,a≠±infinity, b=±in) = inf+i×(2k+0.5, if b>0 ; 2k-0.5, else) |
01-17-2024, 06:34 PM
(This post was last modified: 01-19-2024 12:10 AM by Albert Chan.)
I have extended proof for W0(-∞) = ∞ + pi*I, for generalized case
(01-17-2024 02:06 AM)Albert Chan Wrote: ... (01-17-2024 03:07 PM)Gil Wrote: Cases z=a+ib, a=±inf, b=±inf Unless z is in polar form, we don't know θ. (∞/∞ is indeterminate form) mpmath, with slope=nan, θ = atan2(b,a) = nan p2> log(mpc(inf,inf)) (+inf + nanj) Comment: Technically we do know θ. Above example, 0 ≤ θ ≤ pi/2. IEEE 754-2008 standard pick the mid-point for θ, instead of nan. lua> I.log(I.new(inf,inf)) (inf+0.7853981633974483*I) p3> from cmath import * p3> log(complex(inf,inf)) (inf+0.7853981633974483j) |
