Product function (Π) & Casios
01-26-2024, 07:39 AM (This post was last modified: 01-26-2024 07:41 AM by Matt Agajanian.)
Hi all.
While writing my double factorial program for the 67/97, I came across the product function, Π. This had me wondering. The function is present on the 115 series, but not the 991 calcs.
Maybe it’s just me, but I consider the 991 series to be a more sophisticated lineup than the 115 series. I would even consider the 991EX Classwiz to be an upgrade from any of the 115 models. As such, I would have thought that the product function would be present on the Classwiz.
So, any idea why it’s this way?
Thanks
01-26-2024, 11:18 PM
RE: Product function (Π) & Casios
Easy work around…Use the summation operator for the logs of the function in question, and then take the anti log…
01-27-2024, 03:30 AM
See the 991DEX (DE = Deutschland) version:
https://www.amazon.co.uk/Classico-Scient...B00VB2ISDM
01-27-2024, 03:38 AM
An example to show how it works is the 69! problem. 10^(Summation of log x) from x=1 to 69 produces 1.711224528 *10^98 which is identical to 69!
01-27-2024, 03:44 AM
For answers >10^100, just do summation of, say, log x from 1 to 200. You get 374.8968886 10^.8968886=7.886578674 Final answer is 7.886578674*10^374
01-27-2024, 03:45 AM
Same method applies to any function that you wish to do the product operation on…
01-27-2024, 04:15 AM
Get yourself a WP 34S which has a product function.
Better still use the summation function because it performs a Kahan sum which will be more accurate.
Pauli
01-27-2024, 04:19 AM
(01-26-2024 11:18 PM)lrdheat Wrote:  Easy work around…Use the summation operator for the logs of the function in question, and then take the anti log…
Brilliant! Thanks!
