Pockemul Errors - SOLVED
01-26-2024, 10:11 PM
(This post was last modified: 01-27-2024 09:01 PM by toml_12953.)
I'm using Pockemul 2.7 on Windows 11.
I have a Sharp PC-500S hooked to a CE-140F Pocket Disk Drive and that is hooked to a CE-126P Printer/Cassette Interface. I'm trying to save a program to a pocket disk but no matter what command I try (DSKF, SAVE, FILES, etc.) I get an I/O error. According to the docs, INIT isn't implemented yet. Has anyone here successfully used this combination? If so, how can I save to a disk? Edit: I figured it out. The drive doesn't work when the CE-126P printer is attached. It's a bug of which the author is now aware. Tom L Cui bono? |
