Transition of pyILPER and CAPASM from the Anaconda Cloud to PyPI
02-01-2024, 10:41 AM
(This post was last modified: 02-11-2024 09:44 PM by jsi.)
pyILPER requires the following software component for operation:
CAPASM does only need a Python interpreter to run. At the time of the first versions of pyILPER, the Anaconda Cloud was the only source from which pyILPER and the software dependencies could be obtained for Windows, mac OS and Linux from a single source. The Miniconda application had to be installed for that purpose. But times are changing and the situation is now as follows:
What does that mean for you?
Wat are the differences of an Anaconda and PyPI installation?
What are the long-term prospects for pyILPER support? Unfortunately I don't have access to an Apple M1 system. Therefore I need the support of a mac M1 owner from the community to keep pyILPER on macOS running in the future. Regards Joachim |
02-01-2024, 03:19 PM
RE: Transition of pyILPER and CAPASM from the Anaconda Cload to PyPI
What are the installation instructions for ARM? (typically raspberry PI >2)
HP71B 4TH/ASM/Multimod, HP41CV/X/Y & Nov64d, PILBOX, HP-IL 821.62A & 64A & 66A, Deb11 64b-PC & PI2 3 4 w/ ILPER, VIDEO80, V41 & EMU71, DM41X |
02-01-2024, 07:48 PM
(02-01-2024 03:19 PM)floppy Wrote: What are the installation instructions for ARM? (typically raspberry PI >2) Raspberry PI OS is Debian Linux based. Thus the instructions for Linux apply. If you use the latest Raspberry PI OS you could try to install the pyILPER deb package provided on GitHub, because it is an architecture independent package. Please note:
