hp prime not holding app sequence
02-10-2024, 04:35 AM
Whenever i change the app sequence on my hp prime, after some time the apps seem to be messed up. i dont know what the problem is
02-10-2024, 06:38 PM
RE: hp prime not holding app sequence
What is your sort opion selected?
Günter
02-11-2024, 04:53 AM
Thanks for ur reply!
Its set to fixed
02-11-2024, 07:52 PM
(02-11-2024 04:53 AM)Ruhan Wrote:  Hi,
Its set to fixed
Then it should work, hmm...
sorry no idea
Günter
02-11-2024, 10:30 PM (This post was last modified: 02-12-2024 06:23 AM by komame.)
(02-10-2024 04:35 AM)Ruhan Wrote:  Whenever i change the app sequence on my hp prime, after some time the apps seem to be messed up. i dont know what the problem is
This is a known issue:
https://www.hpmuseum.org/forum/thread-19881.html
When you perform a soft-reset (e.g., On+Symb) or the device simply resets itself due to some bug, the order of applications in Fixed mode is forgotten.
02-13-2024, 03:20 AM
Its been working for some time now. Another problem that i was facing is that whenever i plug my calculator in and open the connectivity kit the projection tab doesnt work, by that i mean whenever i click the projection tab it is just blank.
