(HP71B) MEM installed; HowTo evaluate?
02-13-2024, 03:44 PM
(This post was last modified: 02-13-2024 03:48 PM by floppy.)
I have currently an HP71B with HP-IL in the hands with 2x32kb and CMT-96 in the card reader. It show Code: >MEM Code: >VER$ Where do the 20746 add coming from? Any explanation is welcome HP71B 4TH/ASM/Multimod, HP41CV/X/Y & Nov64d, PILBOX, HP-IL 821.62A & 64A & 66A, Deb11 64b-PC & PI2 3 4 w/ ILPER, VIDEO80, V41 & EMU71, DM41X |
02-13-2024, 04:06 PM
(This post was last modified: 02-13-2024 04:07 PM by KeithB.)
RE: (HP71B) MEM installed; HowTo evaluate?
Did you count the 16K that it has internally?
You can also use a port specifier in the MEM command to see just how much is in each port. |
02-13-2024, 04:13 PM
Also, SHOW PORT will show every port, with its capacity and type.
type 0 main RAM 1 independent RAM 2 ROM 3 EEPROM Cambridge, UK 41CL/DM41X 12/15C/16C DM15/16 17B/II/II+ 28S 42S/DM42 32SII 48GX 50g 35s WP34S PrimeG2 WP43S/pilot/C47 Casio, Rockwell 18R |
02-13-2024, 04:17 PM
The ports should be numbered as follows, I think:
0, 0.01–0.03 internal 4x 4KB RAM 0.05 HP-IL module slot 1–4 front ports 5.x card reader slot Cambridge, UK 41CL/DM41X 12/15C/16C DM15/16 17B/II/II+ 28S 42S/DM42 32SII 48GX 50g 35s WP34S PrimeG2 WP43S/pilot/C47 Casio, Rockwell 18R |
02-13-2024, 04:37 PM
I updated the machine with more RAM modules I had by hand (now CMT 96 and 2x32 and 1x64 and 1xFORTH)
>SHOW PORT Code: 0.05 16384 2 which is 0.05 HPIL 0.. 4096*4 (4096 = 4k *1024) 1.. 32k RAM 2.. 32k RAM 3.. 16k ROM from Forth/ASM 4.. 64k RAM 5.. 98304 (96 * 1024 ) Lovely quick answer from all. Thanks a lot. HP71B 4TH/ASM/Multimod, HP41CV/X/Y & Nov64d, PILBOX, HP-IL 821.62A & 64A & 66A, Deb11 64b-PC & PI2 3 4 w/ ILPER, VIDEO80, V41 & EMU71, DM41X |
02-28-2024, 03:47 PM
(This post was last modified: 02-28-2024 03:47 PM by floppy.)
Now another situation.
Multimod in card reader hpil all 4 ports with a 32KB ram HP71B ON >VER$ Code: HP71:1BBBB HPIL:1A >POKE "2C000","3" HP71B OFF then ON >VER$ Code: HP71:1BBBB FTH:1B EDT:A KBD:C STRU:A MATH:2B JPC:F05 HPIL:1A ULIB:c >MEM() Code: 147804 >SHOW PORT Code: 0.05 16384 2 Why the ports 1 2 3 4 are not indicated with 32KB ? Looks like Multimod has an effect on the output of SHOW PORT because thats different from another post in this thread. HP71B 4TH/ASM/Multimod, HP41CV/X/Y & Nov64d, PILBOX, HP-IL 821.62A & 64A & 66A, Deb11 64b-PC & PI2 3 4 w/ ILPER, VIDEO80, V41 & EMU71, DM41X |
02-28-2024, 03:51 PM
(This post was last modified: 02-28-2024 03:56 PM by Sylvain Cote.)
(02-28-2024 03:47 PM)floppy Wrote: Multimod in card reader, hpil, all 4 ports with a 32KB ram (02-28-2024 03:47 PM)floppy Wrote: Why the ports 1 2 3 4 are not indicated with 32KB ?Because they have been merged (aka claimed) into main memory. HP-71 Owner's Manual, Structure of HP-71 Memory, P.103 to P.108 Sylvain Côté |
02-28-2024, 04:30 PM
(02-28-2024 03:47 PM)floppy Wrote: >VER$ (02-28-2024 03:51 PM)Sylvain Cote Wrote:(02-28-2024 03:47 PM)floppy Wrote: Multimod in card reader, hpil, all 4 ports with a 32KB ram(02-28-2024 03:47 PM)floppy Wrote: Why the ports 1 2 3 4 are not indicated with 32KB ?Because they have been merged (aka claimed) into main memory. More precisely, because you are using here a HP-71 1BBBB. In this version, SHOW PORT doesn't show the memory merged into main memory. This is the only functional difference between the 1BBBB and 2CDCC versions, and that justified a change in the version number 2CDCC , not just 1CDCC. J-F |
02-28-2024, 08:20 PM
There is a SHOWPORT LEX file available, for use on 1BBBB machines that updates the "SHOW PORT" command to include the mainframe RAM; it appears the same as the 2CDCC output.
SHOWLEX can be found on the GOODY1 LIF volume in Joe Horn's OLDP collection: https://www.hpmuseum.org/forum/thread-2520.html --Bob Prosperi |
