[VA] SRC #014 - HP-15C & clones: Accurate NxN Determinants
02-14-2024, 10:13 PM
Hi, all, As it happens, I've been here for 9 years to the day since I joined back in 2015, and to commemorate that momentous event (plus today it's San Valentin's Day, which also helps,) here you are, a brand new SRC #014 dealing with the accurate computation of NxN real matrix determinants and in particular of those matrices whose elements are all integer, where the determinant's value should mandatorily be integer too but frequently isn't when computing it using our beloved HP calculators' DET functionality. The Problem HP vintage models such as the HP-15C, the HP-71B and the RPL models compute the determinant of a square matrix via its LU decomposition, which is a fast, efficient way to do it but involves pivoting and frequently incurs in rounding errors which at times can severely degrade the accuracy of the result, even to the point of rendering it meaningless, with no correct digits whatsoever, and even if the matrix is non-singular. At best, the determinant of all-integer matrices will very frequently be output as a non-integer value. For example,using MATRIX 9 (HP-15C) or DET (HP-71B) we typically get results like these:
M1 = | 3 1 4 | , Det (71B): 1.99999999995 | 1 1 2 | Det Exact: 2 | 29 18 9 | Det (15C): -262.0000005 M2 = | 32 -28 -22 | , Det (71B): -262.000000023 | 18 25 15 | Det Exact: -262 | -19 41 22 7 | Det (15C): -2383.999891 M3 = | 5 19 -14 0 | , Det (71B): -2383.99999934 | -36 16 9 26 | Det Exact: -2384 | 42 -38 14 -38 |
| 50 71 71 56 45 20 52 | | 64 40 84 50 51 43 69 | Det (15C): 1.080204421 AM#1 = | 31 28 41 54 31 18 33 | , Det (71B): 0.97095056196 | 45 23 46 38 50 43 50 | Det Exact: 1 | 41 10 28 17 33 41 46 | | 66 72 71 38 40 27 69 | | 13 72 57 94 90 92 35 | | 40 93 90 99 01 95 66 | | 48 91 71 48 93 32 67 | Det (15C): -2.956799886 AM#7 = | 07 93 29 02 24 24 07 | , Det (71B): 0.0699243217409 | 41 84 44 40 82 27 49 | Det Exact: 1 | 03 72 06 33 97 34 04 | | 43 82 66 43 83 29 61 | As stated above, the internal LU decomposition and subsequent processing to compute the determinant from it will usually incur in rounding errors, which can accumulate to the point that for difficult (but non-singular) matrices the result will be meaningless or having significantly degraded accuracy, frequently outputting integer determinants as non-integers, even for 2x2 matrices, let alone larger ones. To attempt solving this annoying problem, some vintage RPL models had a flag setting that would check if all elements were integer and if so it would round the computed result to an integer value. However, this wasn't foolproof at all and at times this ad-hoc rounding would go awry and result in a ±1 error, usually much bigger than just leaving the non-integer value alone. Worse, the user wasn't informed that this rounding had taken place so in the end the cure was worse than the disease. What to do ? Well, a possible solution would be to use a different algorithm, in particular one which doesn't involve internal arithmetic operations with real numbers, most likely to appear as the intermediate result of non-exact divisions (e.g. 1/3, 293/177, ...) and in 2005 (19 years ago as of 2024 !) I wrote a program to implement this idea, MDET, which you can find featured in this article:
"MDET uses a recursive general expansion by minors procedure and works for any dimensions from 2x2 upwards, though it’s only reasonably efficient for low-order N because computation time grows like N*N!. It produces exact integer results for integer matrices (provided there are no intermediate overflows) [...]" Thus, again, what to do ? As usual, the idea is correct but the chosen algorithm isn't optimal, we need to use a much faster one, in particular faster than O(N*N!), and this is my implementation for the HP-15C of such an algorithm (the HP-71B version is quite straightforward so I'm not including it here.) The HP-15C Implementation This small 50-step (56 bytes = 8 registers) program will accurately compute in polynomial time (not super-exponential time like MDET) the determinant of an arbitrary NxN real matrix A (not necessarily all-integer) for 2 ≤ N ≤ 8 (depending on available memory.) It takes no inputs (but the user must have previously dimensioned and populated the real square matrix A) and it outputs the computed determinant to the display. Program listing ►LBL A 001- 42,21,11 STO 0 027- 44 0 RCL DIM A 002- 45,23,11 STO 1 028- 44 1 STO I 003- 44 25 CLX 029- 43 35 STO 2 004- 44 2 STO E 030- 44 15 DSE 2 005- 42, 5, 2 RCL B 031- 45 12 RCL MATRIX A 006- 45,16,11 CHS 032- 16 STO MATRIX B 007- 44,16,12 DSE 0 033- 42, 5, 0 ►LBL 2 008- 42,21, 2 ►LBL 3 034- 42,21, 3 RCL MATRIX B 009- 45,16,12 RCL 0 035- 45 0 STO MATRIX E 010- 44,16,15 STO 1 036- 44 1 RCL I 011- 45 25 X<>Y 037- 34 STO 0 012- 44 0 STO E 038- 44 15 ►LBL 0 013- 42,21, 0 RCL- B 039- 45,30,12 STO 1 014- 44 1 DSE 0 040- 42, 5, 0 DSE 1 015- 42, 5, 1 GTO 3 ► 041- 22 3 CLX 016- 43 35 RCL MATRIX E 042- 45,16,15 ►LBL 1 017- 42,21, 1 RCL MATRIX A 043- 45,16,11 STO E 018- 44 15 RESULT B 044- 42,26,12 DSE 1 019- 42, 5, 1 x 045- 20 GTO 1 ► 020- 22 1 CHS 046- 16 DSE 0 021- 42, 5, 0 DSE 2 047- 42, 5, 2 1 022- 1 GTO 2 ► 048- 22 2 RCL 0 023- 45 0 MATRIX 1 049- 42,16, 1 TEST 6 024- 43,30, 6 RCL B 050- 45 12 GTO 0 ► 025- 22 0 RCL I 026- 45 25 Notes:
Worked examples Although all examples below deal with all-integer matrices, the program of course works for arbitrary matrices with non-integer elements and produces their determinants with improved accuracy as well. Assume we're using an HP-15C CE in 192-register mode throughout. Example 1. Accurately compute the determinant of the following 4x4 all-integer matrix and compare the result with the determinant computed using the buil-in instruction (MATRIX 9):
M3 = | 5 19 -14 0 | | -36 16 9 26 | | 42 -38 14 -38 | - Initialize: allocate memory for register R2 and clear all matrices to 0x0: 2, DIM (i), MATRIX 0 (MEM: 02 183 08-0) - Dimension and populate the input matrix: 4, ENTER, DIM A, USER, MATRIX 1, -19, STO A, 41, STO A, 22, STO A, 7, STO A, 5, STO A, 19, STO A, -14, STO A, 0, STO A, -36, STO A, 16, STO A, 9, STO A, 26, STO A, 42, STO A, -38, STO A, 14, STO A, -38, STO A - Compute its determinant: FIX 6, GSB A -> -2,384.000000 - Compare the result with the one produced by the built-in function (MATRIX 9): (no need to re-input the matrix as it's left unaltered by the program) RCL MATRIX A, MATRIX 9 -> -2383.999891 As you can see, the built-in instruction returns a non-integer value with degraded accuracy in the last three places, while the program returns the exact integer value. Example 2. Ditto for my 7x7 matric AM#1:
| 64 40 84 50 51 43 69 | AM#1 = | 31 28 41 54 31 18 33 | | 45 23 46 38 50 43 50 | | 41 10 28 17 33 41 46 | | 66 72 71 38 40 27 69 | - Initialize: allocate memory for register R2 and clear all matrices to 0x0: 2, DIM (i), MATRIX 0 (MEM: 02 183 08-0) - Dimension and populate the input matrix: 7, ENTER, DIM A, USER, MATRIX 1, 50, STO A, ..., 69, STO A - Compute its determinant: FIX 9, GSB A -> 1.000000000 - Compare the result with the one produced by the built-in function (MATRIX 9): RCL MATRIX A, MATRIX 9 -> 1.080204421 This time the built-in instruction returns a non-integer value with very severely degraded accuracy in the last eight places, while the program again returns the exact integer value. Example 3. Last but not least, ditto for my 7x7 matric AM#7:
| 40 93 90 99 01 95 66 | | 48 91 71 48 93 32 67 | AM #7 = | 07 93 29 02 24 24 07 | | 41 84 44 40 82 27 49 | | 03 72 06 33 97 34 04 | | 43 82 66 43 83 29 61 | - Initialize: allocate memory for register R2 and clear all matrices to 0x0: 2, DIM (i), MATRIX 0 (MEM: 02 183 08-0) - Dimension and populate the input matrix: 7, ENTER, DIM A, USER, MATRIX 1, 13, STO A, ..., 61, STO A - Compute its determinant: FIX 9, GSB A -> 1.000000000 - Compare the result with the one produced by the built-in function (MATRIX 9): RCL MATRIX A, MATRIX 9 -> -2.956799886 And once more the built-in instruction returns a non-integer value with accuracy so degraded that it loses all 10 digits (and even the sign is wrong !) while the program returns the exact integer value once more. That'll be all, Over and Out. V. All My Articles & other Materials here: Valentin Albillo's HP Collection |
02-15-2024, 08:11 AM
(This post was last modified: 02-15-2024 08:11 AM by EdS2.)
RE: [VA] SRC #014 - HP-15C & clones: Accurate NxN Determinants
Splendid! Thank you - and happy anniversary!
02-17-2024, 09:43 AM
(This post was last modified: 02-17-2024 04:59 PM by J-F Garnier.)
Another great piece of 15c code from Valentin, and nice to come accross the famous AM matrices again !
Moreover, it's a new example of what can be done with the extended memory versions of the classic 15c. Now, the challenge for us poor readers is to understand and possibly to identify the algorithm. Well, I took it as my challenge... (02-14-2024 10:13 PM)Valentin Albillo Wrote: ... this is my implementation for the HP-15C of such an algorithm (the HP-71B version is quite straightforward so I'm not including it here.) And here we come to the readability of RPN code... I had to first translate the code to a high level language (actually the HP-71B BASIC) to be able to understand it. BTW, would RPN/RPL fans be able to port Valentin's code to other Classic machines such as the 41C w/ Advantage pack or the 42S, or even the 28/48 Series, in a way to get a working and readable version, with just the 15c code as a guide? Just curious... The algorithm (as far as I understand it) is really interesting, not only it provides an integer result for integer input matrices (within certain limits of course), but it doesn't use any division at all, and so doesn't have to choose a non-zero pivot. This simplifies the code a lot. The drawback is that it uses 2 auxiliary matrices, which is a real limitation on small machines (such as the original 15C), contrary to other methods such as the Bareiss algorithm. Thanks, Valentin, for this SRC ! J-F |
02-18-2024, 12:41 AM
Bravo, Valentin!
02-20-2024, 03:43 PM
(This post was last modified: 02-20-2024 04:40 PM by J-F Garnier.)
I spent more time to play with this program and have a few more comments on Valentin's SRC #014:
This algorithm is fast, it is much faster than the expansion by minor (illustrated by the XDET program from Valentin), and its speed is actually of the same order of magnitude as the LU-decomposition method used by the HP standard DET functions. Of course, in this implementation, a part of the processing is done as user code so not as fast as it could be in microcode. However, a characteristic of this algorithm and others is that the values of intermediate iterative calculations grow exponentially in magnitude. We should remember that the exact representation of integer numbers is quite limited on our Classic machines: 1E10 for the 15c , 1E12 for the 71B (resp. 1E13 and 1E15 in internal calculations). This SRC is a great illustration of a recent algorithm, but it works on the 15c (or the 71B) only if the input matrix elements are small enough to avoid any integer overflow in the intermediate calculations. As a rule of the thumb, the elements of a 7x7 or 8x8 matrix should not have more than 2 digits. I found examples with numbers of 3 digits that still work well, but others don't. For instance: | 274 213 400 322 341 308 446 | | 202 210 383 295 360 295 450 | | 154 175 332 175 322 361 413 | | 176 147 265 272 328 277 351 | | 111 131 249 182 324 296 340 | | 155 179 329 218 381 399 444 | | 147 127 229 174 245 258 297 | The exact determinant of this matrix is 1, as can be checked on a symbolic system, or just Free42. Valentin's 15c program indeed gives exactly 1 (the 15c built-in DET gives -571) On the contrary, with this matrix: | 477 389 402 515 358 409 289 | | 302 273 282 322 280 283 205 | | 278 231 339 319 343 254 214 | | 432 360 406 502 391 359 319 | | 475 316 509 649 543 393 288 | | 299 304 351 369 459 346 221 | | 526 561 442 441 371 491 445 | Valentin's 15c program gives 7269230 instead of 1 (the buit-in DET gives a hardly better -1337 value, with the wrong sign) This SRC achieved its goal, as far as I'm concerned: learn new (even recent) methods for computing determinants, such as the Bareiss and Bird algorithms, and understand (a little bit) how they are working as well as their limitations on our machines. J-F |
02-26-2024, 10:27 AM
The Bird algorithm (thanks, J-F) implemented for the 42S.
I made two changes: - negate the input matrix A once - shrink the matrix B (remove a row) at every step, as the last row is always filled with zeroes. O, and stack-only. Of course. 00 { 79-Byte Prgm } 01▸LBL "BIRD" 02 ENTER 03 +/- @ 04▸LBL 03 05 X<>Y 06 DIM? 07 X<> ST L @ [B] I -[A] 08 EDIT 09 CLX 10 SIGN 11 X=Y? @ quit when B is a single row 12 GTO 00 13 X<>Y 14 ENTER @ I I 1 -[A] 15 STOIJ 16 R^ 17 RCLEL 18 +/- @ SUM -[A] 19 J- 20 1 21 ENTER @ X Y Z T I,J 22▸LBL 02 @ 1 N-I SUM -[A] I,I-1 23 NEWMAT @ [0] SUM -[A] -[A] 24 PUTM 25 I- 26 RCLEL 27 +/- 28 X<> ST Z 29 STOEL 30 STO+ ST Z 31 R↓ 32 DIM? 33 STO+ ST Y 34 J- 35 FC? 76 36 GTO 02 @ 37 DELR 38 EXITALL 39 R^ 40 STO× ST Y 41 GTO 03 @ 42▸LBL 00 43 RCLEL 44 ENTER 45 EXITALL 46 R↓ 47 END Cheers, Werner 41CV†,42S,48GX,49G,DM42,DM41X,17BII,15CE,DM15L,12C,16CE |
02-27-2024, 10:35 AM
(This post was last modified: 02-27-2024 02:16 PM by Werner.)
.. and, my 15C version.
- works for n=1, too - twice as fast - uses 2n fewer matrix elements - uses R0 and R1 only (not I) - 45 bytes instead of 57 001 LBL B 002 RCL MATRIX A 003 STO MATRIX B 004 RESULT B 005 LBL 3 006 RCL DIM B -- B is ixn 007 X<>Y 008 STO 0 009 STO 1 010 RCL B -- recall Bii 011 DSE 0 -- i := i-1; 012 ISG 1 -- skip 013 RTN -- if B is single row, we're done 014 CHS -- sum := -Bii; 015 RCL 0 016 R^ 017 DIM B -- remove last row, which will be zeroes anyway 018 RCL MATRIX B 019 STO MATRIX E 020 R^ -- put sum back into stack reg. X 021 GTO 0 022 LBL 2 023 0 024 LBL 1 -- zero out row i of E, j=i-1..1 025 STO E 026 DSE 1 027 GTO 1 028 X<>Y 029 DSE 0 030 LBL 0 031 RCL 0 032 STO 1 033 X<>Y 034 STO E -- Eii := sum; 035 RCL- B -- sum := sum - Bii; 036 DSE 1 037 GTO 2 038 RCL MATRIX E 039 RCL MATRIX A 040 x 041 CHS 042 GTO 3 Cheers, Werner 41CV†,42S,48GX,49G,DM42,DM41X,17BII,15CE,DM15L,12C,16CE |
02-28-2024, 07:52 AM
(02-27-2024 10:35 AM)Werner Wrote: .. and, my 15C version. Great, so we can now handle 8x8 matrices on the 15c CE/192 ! Let's try with this matrix I just created (determinant is exactly 1): | 75 43 72 59 37 63 51 67 | | 67 34 64 45 36 55 38 62 | | 85 53 87 74 59 70 67 81 | | 87 49 91 70 50 80 65 86 | | 72 35 73 53 37 69 52 68 | | 65 38 71 62 38 68 62 65 | | 86 56 86 77 56 69 67 80 | | 82 58 100 82 63 79 87 88 | 8 , ENTER , DIM A enter elements into matrix A ... (a bit long) Check the matrix with: RCL MATRIX A , RESULT B , MATRIX 9 (det) -> .9999585581 ( the RESULT B step is important, otherwise the matrix A is no more useable ) Now: GSB B --> 1 exactly ! J-F |
02-29-2024, 10:51 PM
Hi, all, Well, today it's February, 29th so 15 days have elapsed since I posted my OP and it's high time to add some final comments. First of all, thanks to all of you for your interest and most especially to those of you who contributed with code and various improvements, namely J-F Garnier and Werner. Frankly, I expected to get more posts since the subject matter is both interesting, instructive and useful, and the HP-15C CE is still very much fashionable but alas, at a meager 7 posts and 1,000 views in 15 days it wasn't to be. Now I'll comment on some of your messages and various matters: Gene Wrote:Bravo, Valentin! Thanks a lot for your kind appreciation, Gene. J-F Garnier Wrote:Another great piece of 15c code from Valentin, and nice to come accross the famous AM matrices again ! Thank you very much for your appreciation and kind words re my code and difficult matrices. J-F Garnier Wrote:And here we come to the readability of RPN code... I had to first translate the code to a high level language (actually the HP-71B BASIC) to be able to understand it. You didn't post your 15C/RPN to 71B/BASIC program in this thread so I'm posting my original straightforward HP-71B BASIC version below. J-F Garnier Wrote:The algorithm (as far as I understand it) is really interesting, not only it provides an integer result for integer input matrices (within certain limits of course), but it doesn't use any division at all, and so doesn't have to choose a non-zero pivot. This simplifies the code a lot. Indeed. Bird's algorithm doesn't use any divisions at all and that's a big plus, completely eliminating having to care about pivots, having to work with floating point values and having to deal with rounding errors. J-F Garnier Wrote:The drawback is that it uses 2 auxiliary matrices, which is a real limitation on small machines (such as the original 15C) [...] Using two extra matrices is unavoidable, as Bird's method essentially relies on matrix multiplication and this usually requires three different matrices on the HP-15C: A=BxC with distinct matrices A, B, C. J-F Garnier Wrote:This SRC is a great illustration of a recent algorithm, but it works on the 15c (or the 71B) only if the input matrix elements are small enough to avoid any integer overflow in the intermediate calculations. Yes, the size of intermediate results is a problem for many algorithms, including the naive one which in this case would entail adding 5040 terms (each of them a product of 7 elements,) which are sure to be more than 10-12 digits long if the elements are 3-digit long or more, so Bird's algorithm does no worse than others in this regard and usually it does better. J-F Garnier Wrote:This SRC achieved its goal, as far as I'm concerned: learn new (even recent) methods for computing determinants, such as the Bareiss and Bird algorithms, and understand (a little bit) how they are working as well as their limitations on our machines. That's the idea ! J-F Garnier Wrote:Thanks, Valentin, for this SRC ! You're welcome, J-F, again thanks to you for your continued appreciation. Werner Wrote:The Bird algorithm (thanks, J-F) implemented for the 42S. Excellent ! Werner Wrote:.. and, my 15C version. - works for n=1, too, - twice as fast, - uses 2n fewer matrix elements, - uses R0 and R1 only (not I), - 45 bytes instead of 57 Most excellent ! The idea of removing a zero row at every step is really clever. Congratulations ! Now for my original BASIC program for the HP-71B. It is this 4-line, 191-byte suprogram called BIDET (BIrd's DETerminant, pun most definitely intended):
110 FOR I=2 TO N @ FOR J=1 TO I-1 @ E(I,J)=0 @ NEXT J @ NEXT I 120 FOR I=1 TO N @ S=0 @ FOR J=I+1 TO N @ S=S-B(J,J) @ NEXT J @ E(I,I)=S @ NEXT I 130 MAT B=E*A @ MAT B=-B @ NEXT K @ D=B(1,1) Let's try it with J-F's second 7x7 matrix, namely:
| 302 273 282 322 280 283 205 | | 278 231 339 319 343 254 214 | | 432 360 406 502 391 359 319 | | 475 316 509 649 543 393 288 | | 299 304 351 369 459 346 221 | | 526 561 442 441 371 491 445 | >DESTROY ALL @ OPTION BASE 1 @ DIM A(7,7),D @ MAT INPUT A (... enter all 49 elements ...) and then let's compute the determinant while also gauging the exactness of the results: >CFLAG INX @ CALL BIDET(A,D) @ D,FLAG(INX) 1 0 so the determinant is computed as 1 and the INeXact flag is 0 (false) so the value is exact. Now let's compare with the assembly-language DET function: >CFLAG INX @ DET(A),FLAG(INX) -53.8832026193 1 and this time the INeXact flag is 1 (true) so the computed value is truly inexact. A whole lot ! As for my HP-15C program returning 7269230 instead of 1 (J-F dixit), it can possibly be made to return the exact value by combining it with partitioned matrix techniques, as decribed in my article. We could try partitions into 4 blocks (from 1x1... to 6x6...) but perhaps the combo 4x4, 4x3, 3x4, 3x3 would possibly avoid intermediate overflows and result in the exact value being produced. This is an area worthy of research for those interested. Last but not least, the same way that J-F translated my 15C/RPN program to 71B/BASIC, the reverse translation is easy to perform manually line by line and results in translating my 71/BASIC subprogram into my exact 15C/RPN original program, like this: MAT B=A @ FOR K=1 TO N-1 @ MAT E=B ►LBL A RCL DIM A N STO I RI=N STO 2 DSE 2 K=N-1 RCL MATRIX A STO MATRIX B MAT B=A ►LBL 2 FOR K loop RCL MATRIX B STO MATRIX E MAT E=B FOR I=2 TO N @ FOR J=1 TO I-1 @ E(I,J)=0 @ NEXT J @ NEXT I RCL I N STO 0 I=N ►LBL 0 FOR I loop STO 1 DSE 1 J=I-1 CLX 0 ►LBL 1 FOR J loop STO E E(I,J)=0 DSE 1 GTO 1► NEXT J DSE 0 1 RCL 0 TEST 6 (X#Y?) GTO 0► NEXT I S=-B(N,N) @ E(N,N)=0 @ FOR I=N-1 TO 1 STEP -1 @ E(I,I)=S @ S=S-B(I,I) @ NEXT I RCL I N STO 0 I=N STO 1 J=N CLX 0 STO E E(N,N)=0 RCL B B(N,N) CHS S=-B(N,N) DSE 0 I=N-1 ►LBL 3 FOR I loop RCL 0 I STO 1 J=I X<>Y S STO E E(I,I)=S RCL- B S=S-B(I,I) DSE 0 GTO 3► NEXT I MAT B=E*A @ MAT B=-B @ NEXT K @ D=B(1,1) RCL MATRIX E RCL MATRIX A RESULT B x MAT B=E*A CHS MAT B=-B DSE 2 GTO 2► NEXT K MATRIX 1 I=1, J=1 RCL B B(1,1) That's all for now, best regards. V. All My Articles & other Materials here: Valentin Albillo's HP Collection |
03-01-2024, 07:57 PM
(This post was last modified: 03-04-2024 07:18 AM by Werner.)
I wasn't done yet ;-)
Here is a low memory version of the Bird algorithm. For a problem of order n it needs only n^2 + 3*n matrix elements. It uses RI, and R0-R2 so requires at least 2 DIM (i). Drawbacks: - it is slower than my previous version (yet, for AM7, still faster than Valentin's original). - it needs yet another matrix, D - it's a bit larger (80 bytes = 12 registers) - the code is somewhat more involved ;-) 001 LBL D 002 CLX 003 STO 0 004 DIM D -- erase D and E 005 DIM E 006 RCL DIM A 007 STO 1 008 STO I 009 1 010 X<>Y 011 DIM D -- D and E 1xn 012 DIM E 013 RCL DIM A 014 RCL g A 015 DSE I -- i := n - 1; 016 ISG 0 -- R0=1 and skip 017 RTN -- quick return when n=1 018 STO- D -- d(n) := -a(n,n) 019 RESULT B 020 LBL 1 -- i=n-1 to 1 021 RCL DIM A 022 STO 1 023 RCL D -- x := d(n); 024 RCL I 025 ENTER 026 RCL g A 027 STO- D -- d(n) := d(n) - a(i,i); 028 X<>Y 029 RCL I 030 STO 1 -- k := i; 031 X<>Y 032uSTO E -- e(k) := x; k := k + 1; 033 LBL 8 -- e(k) := a(i,k); k=i+1..n 034 RCL I 035 RCL 1 036 RCL g A 037uSTO E 038 GTO 8 039 RCL DIM A 040 RCL- I 041 STO 2 042 LBL 2 -- for nj=n-i to i step -1 043 RCL MATRIX E 044 RCL MATRIX A 045 x 046 CHS 047 RCL I 048 RCL+ 2 049 STO 1 050 DSE 1 -- j := nj + i - 1; 051 RCL D -- d(j) 052 1 053 RCL I 054 RCL g B -- b(i) 055 STO- D -- d(j) := d(j) - b(i); 056 X<>Y 057 RCL I 058 STO 1 -- k := i; 059 X<>Y 060uSTO E -- e(k) := d(j); k := k + 1; 061 LBL 9 -- e(k) := b(k); k=i+1..n 062 RCL B 063uSTO E 064 GTO 9 065 DSE 2 066 GTO 2 067 DSE I 068 GTO 1 069 RCL B 070 RTN Hope you like it, Werner 41CV†,42S,48GX,49G,DM42,DM41X,17BII,15CE,DM15L,12C,16CE |
03-06-2024, 06:18 PM
(This post was last modified: 03-06-2024 06:22 PM by Werner.)
Shorter, and a bit slower (still marginally faster than Valentin's original)
max. orders possible:
# Generated 2024-3-6 11:35 Central European Standard Time. 000 { } 001 { 42 21 14 } f LBL D 002 { 1 } 1 003 { 44 0 } STO 0 004 { 45 23 11 } RCL DIM A 005 { 44 25 } STO I 006 { 43 35 } g CLx 007 { 42 23 14 } f DIM D -- erase D 008 { 33 } Rv 009 { 42 23 14 } f DIM D -- D,E 1xn 010 { 42 23 15 } f DIM E 011 { 42 26 12 } f RESULT B 012 { 42 21 1 } f LBL 1 -- for i=n to 1 step -1 013 { 45 23 11 } RCL DIM A 014 { 16 } CHS 015 { 45 25 } RCL I 016 { 44 1 } STO 1 017 { 40 } + 018 { 44 2 } STO 2 -- nj := -(n-i); 019 { 43 35 } g CLx 020 { 44 16 15 } STO MATRIX E 021 { 42 5 15 } f DSE E -- E := -ei; 022 { 42 21 2 } f LBL 2 -- for nj=i-n..0 023 { 45 16 15 } RCL MATRIX E 024 { 45 16 11 } RCL MATRIX A 025 { 20 } * 026 { 16 } CHS -- B := -E*A; 027 { 45 25 } RCL I 028 { 45 30 2 } RCL - 2 029 { 44 1 } STO 1 -- j := i - nj; 030 { 45 14 } RCL D -- t := D(j); 031 { 1 } 1 032 { 45 25 } RCL I 033 { 45 43 12 } RCL g B 034 { 44 30 14 } STO - D -- D(j) := D(j) - B(i); 035 { 43 35 } g CLx 036 { 1 } 1 037 { 45 25 } RCL I 038 { 44 1 } STO 1 039 { 44 43 12 } STO g B -- B(i) := t; 040 { 42 21 9 } f LBL 9 -- E(k) := B(k); k=i..n 041 { 45 12 } RCL B 042 { 44 15 u } u STO E 043 { 22 9 } GTO 9 044 { 42 6 2 } f ISG 2 -- next nj; 045 { 22 2 } GTO 2 046 { 42 5 25 } f DSE I -- next i; 047 { 22 1 } GTO 1 048 { 45 14 } RCL D 049 { 16 } CHS 050 { 43 32 } g RTN # End. Cheers, Werner (that's it, I think. I see no immediate further improvements) (incidentally, while I used JRPN to produce the above listing, the program does not run on the simulator as-is, as it contains a bug (the simulator, not the program) - insert ENTER just after RCL D in line 030 to make it work on JRPN) 41CV†,42S,48GX,49G,DM42,DM41X,17BII,15CE,DM15L,12C,16CE |
User(s) browsing this thread:
