testing image insertion - LTR marks (?) automatically inserted instead
02-21-2024, 04:44 PM (This post was last modified: 02-21-2024 05:03 PM by jebem.)
Trying to insert an image.
Got http 404 when following the link.
It seems that the entered URL is modified automatically to a different URL where the sequence %E2%80%8B (LTR mark???) is inserted in the original URL string.
This is the correct, entered URL pointing to the image:
"https://blogger.googleusercontent.com/img/b/R29vZ2xl/AVvXsEiT3K8KxwjI9puVh1DpGbHtGytbP3URqWIGAFqmuL_8-U-YZQPnHyRAcuEdTjyuHdxKH3g2mt94GenggZ5MtGMZdaBbozknUY6LuEYL4kB3YjSdmpcfxqRAK44rb6o​fCpt8qjnxJ6BC2krdzPll74kms2k_LGS2GPyq1IwSKYF7-BlPfsmWJBzA-LSuEV8/s1653/SAM_2131.JPG"
The above URL was copied directly from the browser address area, and pasted into the URL address in the MoHPC system.
And this is what the browser has after clicking on the created link below:
"https://blogger.googleusercontent.com/img/b/R29vZ2xl/AVvXsEiT3K8KxwjI9puVh1DpGbHtGytbP3URqWIGAFqmuL_8-U-YZQPnHyRAcuEdTjyuHdxKH3g2mt94GenggZ5MtGMZdaBbozknUY6LuEYL4kB3YjSdmpcfxqRAK44rb6o​%E2%80%8BfCpt8qjnxJ6BC2krdzPll74kms2k_LGS2GPyq1IwSKYF7-BlPfsmWJBzA-LSuEV8/s1653/SAM_2131.JPG"
img 1
Apparently there is a maximum size for the URL string, as seen in the first URL above, there is a line break (return) after the "...pcfxqRAK44rb6o​" chars.
If I copy this URL and paste it into notepad, the %E2%80%8B are also inserted after the string "...pcfxqRAK44rb6o".
And i just edited this post and checked again the URL string that I have entered as the correct one at the top, it is correct, no %nn chars added.
What is the maximum size for a URL address in the system?
02-22-2024, 10:35 AM (This post was last modified: 02-22-2024 10:36 AM by jebem.)
RE: testing image insertion - LTR marks (?) automatically inserted instead
Testing with another file repo service, that generates shorter URL addresses.
https://drive.google.com/file/d/10EwC4F7...qgeFK/view
https://drive.google.com/file/d/1TeBgS0a..._cAba/view
Yap, shorter URL links seems to work fine.
Thank you, Thomas!
