size(list) Results
02-23-2024, 04:47 PM
size(list) Results
I seem to run into a problem every time I try to use lists and size, as they can unexpectedly turn into a list of lists instead, and I do not naturally get the way to work with them.
Lets say I have
LOCAL DI:=idivis(711000000);
PRINT (DI);
that prints "[1,2,3,4,5,6,8.........]" Those square brackets mean it is a matrix or vector, don't they?
In the manual idivis() says it returns a list.
So, If I then:
Print size(DI);
It returns {294}. - which means that idivis is returning a list of one containing a matrix/vector of length 294? Is there not a way to have it only return a list of 294?
It is quite confusing.
How can I then access the size of DI as a number - how do I get the result of size(DI) as a number, not a list/vector/matrix.
02-23-2024, 05:11 PM
RE: size(list) Results
Bonjour matalog
SIZE() renvoie une liste pour la dimension des matrices {lignes,colonnes}.
Pour un vecteur SIZE() considère qu'il s'agit d'une matrice à 1 seule ligne et renvoie {colonnes}.
Pour obtenir la taille sous forme de nombre vous pouvez faire GET(SIZE([vecteur]),1).
Espérant vous avoir aider.
Hello matalog
SIZE() returns a list of matrix dimensions {rows,columns}.
For a vector, SIZE() assumes it is a 1-line matrix and returns {columns}.
To obtain the size as a number, you can do GET(SIZE([vector]),1).
Hope to have helped you.
Sorry for my english
02-23-2024, 05:36 PM
You can also set DI to a list with :
LOCAL DI:=mat2list(idivis(711000000));
then size(DI) will return 294.
02-23-2024, 06:06 PM
(02-23-2024 04:47 PM)matalog Wrote:  In the manual idivis() says it returns a list.
From HP Prime help screen, Yes
From pdf "Symbolic computation and Mathematics with the calculator HP Prime", No
Quote:idivis returns the vector whose components are the divisors of an integer.
Quote:It is quite confusing.
Instead of size/SIZE, use len/dim
