HP41c screen cleaning
03-12-2024, 06:35 AM (This post was last modified: 03-12-2024 06:49 AM by zixingcheche.)
Does anyone know how to clean the dust inside the screen of HP41C? (early version, SN 1937A00711)
I use the air blower, but it seems not effect.
BTW, the same air blower wors well when cleaning the late version 41C.
Thanks!
Attached File(s) Thumbnail(s)
03-13-2024, 03:33 PM
RE: HP41c screen cleaning
Hi zixingcheche,
i have cleaned already several HP41 display covers, the best way is to desolder the display.
This is not difficult and lasts only some minutes. Take a needle under each leg, desolder the pin and lift up with little force. Do not apply too much force that the cnducting path does not come up. If this happens it is indeed easy to fix. Pull out the display with caution and clean.
After cleaning the display and the cover your HP will look like new.:-)
Ralf
/41/48/
03-14-2024, 12:19 AM
Hi Ralf,
Thanks for your suggestion, it sounds good.
I will try this.
Thanks!
03-14-2024, 10:33 AM
(03-13-2024 03:33 PM)Hiwi Wrote:  Hi zixingcheche,
Ralf
Hi Ralf
I just finished cleaning the LCD according to your suggestion.
it takes 10 minutes in total.
Now the LCD is very clean and without big dusts.
Thank you!
03-15-2024, 11:49 AM
Perfect!
/41/48/
