see googles new calculator will calc factorials over 3000
04-06-2024, 11:50 AM
See googles new calculator update will calculate factorials over 3000 see attached screenshot
04-07-2024, 06:53 AM
RE: see googles new calculator will calc factorials over 3000
That's great, thanks for highlighting! My Pixel 4A goes to a maximum of 19,515! and then silently refuses to calculate any higher factorial. Curious what is the limit...
Rob 35, 12C, 17BII, 27S, 28S, 32SII, 48G, 49G, 50G, 35S. |
04-07-2024, 09:22 AM
N! going up to "over 3000" sounds like the calculator uses a decimal floating-point format with a four-digit exponent. (Free42 Decimal 1.4.x used a format with those properties, and could handle up to 3248!)
N! going up to 19515 sounds like the calculator uses a binary floating-point format with an exponent going up to 249,999. Having an exponent that represents a power of two but whose maximum value looks very decimal is pretty weird, but that's all I can make of it. :-) |
04-09-2024, 11:26 AM
(This post was last modified: 04-13-2024 08:23 PM by johanw.)
It is not an exact answer so I assume Google implemented just Stirlings formula for faculties over a certain number.
04-09-2024, 08:20 PM
I can’t find an end with WOLFRAM ALPHA.
