Copy Digital Cassettes?
04-09-2024, 02:35 PM
Is there any way to copy one digital cassette (HP 82161A) to a second drive with one command using an HP-71 or HP-75?
The COPY command doesn't accept wildcards so I can't just do this: Code: COPY "*:C1" TO ":C2" or Tom L Cui bono? |
04-09-2024, 03:58 PM
(This post was last modified: 04-09-2024 04:01 PM by Sylvain Cote.)
RE: Copy Digital Cassettes?
On the HP-75 you have the 00075-13015 Duplication & Privacy Solutions Book that allow you to clone cassettes.
The solutions book comes with two magnetic cards "MCOPY" and "INSTALL" that you have to load into the HP-75. Those cards are inside the 00075-13015 Duplication & Privacy [soft tape] (sc).dat LIF volume. On the HP-71 there is a MCOPYLEX file that should do the same as the HP-75 one. The LEX is inside the lexfl1.dat LIF volume in Joe Horn Swap Files. Joseph K. Horn → LEXicon & Titan Files Documentation The third option would be to write a small BASIC program that read the cassette catalog into memory then copy the files one by one. Sylvain Côté |
