Library 4
04-19-2024, 05:31 PM
(This post was last modified: 04-19-2024 06:34 PM by BitWiz.)
Library 4
Problem solved: LIFMOD with -e option.
I need library #4 for th AMC OS/X ROM. The one that came with the clonix files does not seem to be the correct one. I was able to download library4 v:R59b but it is in MOD form. How do I convert from MOD to ROM? Is this the correct version for that? Is it compatible with the HEPAX module that also uses library 4? I could not find anything in the LIF utilities for this. Thank you.... |
04-20-2024, 12:05 PM
(This post was last modified: 04-20-2024 07:10 PM by rprosperi.)
RE: Library 4
You can find it here:
http://www.ho41.org/LibView.cfm?Command=...temID=1027 (replace 'ho with 'hp') Most of Angel's files, and especially the newest versions, are available at Warren's fabulous site. --Bob Prosperi |
04-20-2024, 01:37 PM
(This post was last modified: 04-20-2024 08:53 PM by Sylvain Cote.)
RE: Library 4
Library 4 R58 (-LIB#4-R58") is included in rom_files_220302.zip (LIBRARY4.ROM)
Library 4 R59 (-LIB#4-R59") is included in rom_files_220422.zip (LIBRARY4.ROM) Library 4 R60 (-LIB#4-R60") is included in rom_files_220722.zip (LIBRARY4.ROM) R60 is the latest revision, also included in rom_files_240325.zip (LIBRARY4.ROM) edit: oups, copy paste error, links corrected, thanks Mike. Sylvain Côté |
04-20-2024, 06:14 PM
RE: Library 4
Bob,
Thank you. The URL got blocked for some reason. Mike |
04-20-2024, 06:54 PM
RE: Library 4
Sylvain,
Thank you. The first 3 of your link all point to rom_files_220302.zip. I have corrected the links here: Library 4 R58 (-LIB#4-R58") is included in rom_files_220302.zip (LIBRARY4.ROM) Library 4 R59 (-LIB#4-R59") is included in rom_files_220422.zip (LIBRARY4.ROM) Library 4 R60 (-LIB#4-R60") is included in rom_files_220722.zip (LIBRARY4.ROM) R60 is the latest revision, also included in rom_files_240325.zip (LIBRARY4.ROM) I'm going to systemwide to see if I can fine the rest. Mike |
