AMC OS/X+ .ROM Images
04-26-2024, 02:32 AM
I am trying to extract the .ROM files from the file OSX_BS4X.MOD and I get the following error:
>h:\Clonix\MODFile.exe -e OSX_BS4X OSX_BS4X.mod AMC OS/X Module - 4x Banks & Lib#4 - R51 W&W and others as noted ERROR: File Open Failed: -AMC"OS/X.ROM What is causing this? How can I extract the .ROM files for my NoV-64D? Does this .MOD file match Revision 5b of the AMC_OS/X+ Module documentation found here: AMC_OS/X+ Manual[/font]? If not how do I find the latest documentation and images? Thank you, Mike |
04-26-2024, 06:33 AM
(This post was last modified: 04-26-2024 06:35 AM by brouhaha.)
RE: AMC OS/X+ .ROM Images
The problem may be due to the slash character. You could try first creating a directory named by the part of the path prior to the slash.
04-26-2024, 10:48 AM
(04-26-2024 02:32 AM)BitWiz Wrote: What is causing this? The manual posted at that location is the latest indeed, As per the ROM files, here you go... Cheers "To live or die by your own sword one must first learn to wield it aptly." |
04-26-2024, 03:49 PM
(04-26-2024 10:48 AM)Ángel Martin Wrote:(04-26-2024 02:32 AM)BitWiz Wrote: What is causing this? Angel, Thank you very much. I am thinking of making a customized ROM for personal use. Taking what I am interested in (M-CODE, HP-IL, NOV/Clonix and synthetic programming) from multiple ROMs whose source is available. Is the source for your ROMs (Specifically OS/X, WARP, etc) available? I totally understand if they are not. Feel free to PM me if you would like to take this conversation off line. Thank you for all of your work for the HP calculator community. Mike |
04-28-2024, 07:08 AM
Mike, let me prepare a suitable pdf set with the most recent version first, then I'll be glad to share it with anyone interested. Stay tuned...
04-28-2024, 03:20 PM
Angel,
Thank you. Mike |
