OLD HP-41 Tapes from the 80's uploaded
05-01-2024, 10:10 PM
I have uploaded 8 digital micro-cassettes of programs for the 41 to LIF compatible .DAT files with my PIL-Box.
The tapes are labeled as follows: 41-Atlanta June 1, 1982 HP-41 System Demo PPCJ V9 & !0 - No Priv FL D30 D32 D35 D36 D37 These we all made in or around 1982 in conjunction with the CHiP club. I believe most of these were made for me by Mr. George A Duba (thank you Al). I have attached the .DAT files. I hope there is something new here that hasn't been archived before. I will upload what ever is on my HP-71 tapes next and post them in a new message. |
09-11-2024, 08:30 AM
RE: OLD HP-41 Tapes from the 80's uploaded
Hello BitWiz,
thanks for your shared files, unfortunatly trying to convert .DAT in .RAW format or .TXT format I have always the same error i.e.: -->hp41uc /d=hp41demo_1jun82 /r -->Error: invalid ASCII hex-digit in 4-byte header [ 80 ] please what I'm doing wrong?? Thanks Roberto |
09-11-2024, 02:24 PM
(This post was last modified: 09-11-2024 02:31 PM by Dave Frederickson.)
(09-11-2024 08:30 AM)roberto_p Wrote: please what I'm doing wrong?? The issue is that there are multiple file types with a .DAT extension. The file is in LIF disc format so there's no need to convert it. Just mount the file in ILPer or one of it's offspring. Note: LIF disc format is different than LIF file format. HP41UC works with the file format. |
09-11-2024, 03:33 PM
Code: unzip -d HP-41Tapes HP-41Tapes.zip Code: Archive: HP-41Tapes.zip Code: cd HP-41Tapes Code: 41ATLANTA.DAT Code: lifdir HP41DEMO_1JUN82.DAT Code: Volume : ? Code: lifget -r HP41DEMO_1JUN82.DAT DISP disp.raw Code: LBL "DISP" Sylvain Côté |
09-11-2024, 04:34 PM
As Sylvain has demonstrated, Joachim's LIFUTILS provide everything you need to manipulate LIF files.
I like to use pyILPER as a front-end for LIFUTILS. If a Drive device is disabled in pyILPER, this enables right-mouse-button integration with LIFUTILS. One can even decode a HP41 program file without typing a single command. https://github.com/bug400 |
09-12-2024, 07:57 AM
+++Many thanks Sylvain and Dave!!!
I didn't know this utility yet ----------------------------------------------------- Kind regards Roberto |
