Collect() does not work as should be
05-03-2024, 04:44 PM
When the following command is entered in the CAS view
collect(a*z^2+q*z+p*z^2+o+n*z+y,z) I get: a*z^2 +n*z+o+p+z^2+q*z+y whereas that same command was entered in XCas, and the answer was z*(z*(a+p)+n+q)+o+y which is the correct one as per the manual of HP Prime. My HP Prime model is: SW version: 2.1.14730 Hardware Version: D OS: V2.060.650 |
05-03-2024, 06:45 PM
RE: Collect() does not work as should be
Hi, amindanial
Collect (factors) results depends on CAS setting. If you have Simplify=Max, factors get "simplified" away. We do have a bug, variable supplied not working (Simplify=Min) > collect(x^2+3x+2) → (x+1)*(x+2) > collect(x^2+3x+2,x) → x*(x+3)+2 ??? |
05-04-2024, 03:21 AM
Thanks Albert for your clarification.
However, what is the bug you are talking about "We do have a bug, variable supplied not working"? |
05-04-2024, 03:37 AM
collect(x^2+3x+2) and collect(x^2+3x+2, x) should give the same answer (x+1)*(x+2)
05-04-2024, 05:01 AM
(This post was last modified: 05-04-2024 05:04 AM by amindanial.)
RE: Collect() does not work as should be | |||
05-04-2024, 12:10 PM
(This post was last modified: 05-04-2024 12:11 PM by Albert Chan.)
XCas ans HP Prime use the same engine ... of course screenshot matched.
But is it right? How is collect(Poly, Var) supposed to work? collect(Poly, Var) \(\;\overset{?}{=}\;\) poly2symb(symb2poly(Poly, Var), Var) XCas help does not even show this optional Var form, only collect(Poly or LstPoly) XCas manual did (optional α, not Var), but no example of what to expect. |
