Edit notes
05-06-2024, 12:41 AM
Edit notes
I'm using the HP Connectivity Kit from Macbook.
How can I edit, or transfer a notes from and to the HP Prime G2, and preserving the notes format, like bold, alignment, list, formula, etc... ? |
05-07-2024, 03:46 AM
RE: Edit notes
Currently using the connectivity kit to transfer notes to/from a calculator causes the note to lose the applied styling. I opened a report on the bug tracking site but in the mean time there is a work around that uses the virtual calculator instead of the connectivity kit.
You can make a styled note on the HP Prime Virtual Calculator and connect your physical calculator to your computer. In the Shift Notes menu with the note highlighted a "Send" button should appear on the on the soft key menu, pressing it will transfer a copy of the note to the connected calculator and preserve the applied styles. - neek |
