Finance problems (TVM) on hp 49G+ hp 50G Periods and compounds per year are different
06-11-2024, 11:05 PM
Post: #21
RE: Finance problems (TVM) on hp 49G+ hp 50G Periods and compounds per year are diffe
TVM to get i2 = (1+i)^n - 1
lua> n, i = 12, 0.005 lua> tvm(n, i, -1, 0, nil) - 1 -- Naive way, probably not accurate 0.06167781186449961 lua> tvm(n, i, 0, -i, nil) -- Werner's way, very accurate 0.06167781186449957 lua> expm1(log1p(i)*n) -- reference 0.06167781186449957 (06-08-2024 11:47 PM)Albert Chan Wrote: Solve with split loan method I just noticed loan #2 can use Werner's trick to solve x too! To make this clear, lets scale PV column to -1, matching naive way. {PV, PMT, FV} = {x, 0, (pv+fv)-x} --> scale by (-1/x) --> {-1, 0, 1 + -(pv+fv)/x} --> i2 = -(pv+fv) / x --> x = -(pv+fv) / i2 lua> n,i,pv,pmt,fv = -40, -0.5, 2000, 1000, -1900 Solve for x, both ways: lua> -(pv+fv) / (tvm(n,i,-1,0,nil)-1) -- Naive way -9.094947017737554e-11 lua> -(pv+fv) / tvm(n,i,0,-i,nil) -- Werner's way -9.094947017737554e-11 We can of course scale the problem, shift x to PMT column {PV, PMT, FV} = {0, -i, i2} --> scale by (x/-i) --> {0, x, (pv+fv)/i} lua> tvm(n,i,0,nil,(pv+fv)/i) -9.094947017737554e-11 |
