need help with FCAT program for HP 42S
05-21-2024, 06:11 AM
In the HP-42S RPN Scientific Programming Examples and Techniques manual, Edition 1 July 1988, page 54, program FCAT line :
50 LBL 14 what is the purpose of this line? I spent 4 hours keying in this program - GTO A is hardly intuitive. My first and previous calculator was the 32S and the 42S (actually Free42) is several levels more complex. So I am relearning with a view to writing a superior circle-triangle-circle program with all the bells and whistles. FCAT seemed a good program to learn from but this step has me stumped. Was there an erratum about this? Thanks. |
05-21-2024, 04:21 PM
RE: need help with FCAT program for HP 42S
After a cursory glance at page 54 of ‘Programming Examples and Techniques’, it can be assumed that in the case of this programme (and only for this programme) it will be a kind of placeholder for ‘Do nothing’.
05-21-2024, 05:56 PM
For those who want to try the program:
Code: 00 { 234-Byte Prgm } |
05-22-2024, 01:26 AM
Appears to be a NO-OP.
Curiously, there is also a >LBL 14 at line 53 of FL (see p. 168) of the PPC ROM manual. 17bii | 32s | 32sii | 41c | 41cv | 41cx | 42s | 48g | 48g+ | 48gx | 50g | 30b |
05-22-2024, 07:17 AM
(This post was last modified: 05-23-2024 12:55 AM by Thomas Klemm.)
If you wonder why LBL 14 is used and not LBL 99 to indicate a NO-OP: it is the highest one-byte label.
From LBL 15 on they consume two bytes. And then they give the precious byte away with a useless use of a RTN statement: Code: 89 RTN |
05-23-2024, 12:17 AM
(05-22-2024 07:17 AM)Thomas Klemm Wrote: If you wonder why LBL 14 is used and not LBL 99 to indicate a NO-OP: it is highest one-byte label. Although END returns from a subroutine the same way as RTN, RTN is a tad faster, which is especially noticeable when the subroutine is called many times in a loop. So RTN END is not a useless waste of one byte, but rather slightly improves execution time. <0|ɸ|0> -Joe- |
05-23-2024, 12:51 AM
RE: need help with FCAT program for HP 42S | |||
05-23-2024, 02:55 AM
(05-23-2024 12:51 AM)Thomas Klemm Wrote:(05-23-2024 12:17 AM)Joe Horn Wrote: So RTN END is not a useless waste of one byte, but rather slightly improves execution time. This made me laugh out loud. I'm only glad my wife didn't hear, can you imagine trying to explain why this is funny to a non-calculator nerd... --Bob Prosperi |
05-23-2024, 04:35 AM
Thanks for the answers.
Pg 131 of the owner's manual states: "Without the PSE instructions (lines 03 and 06) the program would run too fast to see the first two messages. A PSE is not needed after the last AVIEW because the viewed information remains in the display after the program stops. " So in the case of FCAT, the PSE is unnecessary. According to my deconstruction of FCAT, LBL 12 is a subroutine so it may be entered elsewhere thus RTN is required there. Regardless, I have enough OCD to require that. Wow, we now have a working FCAT that is 231 bytes in size. I wonder how the exalted HP engineers/editor missed these? Or is this a test ? Should I expect an invite into a secret society? |
05-23-2024, 06:56 AM
Erratum:
88 PSE turns out to be necessary. If you attempted to set/clear a system flag, the 87 AVIEW would be rapidly replaced by 20 "FLAG CATALOG" I saved one byte. I don't think there is anything else to add to this thread. PS I worked for IBM, 30 years. |
05-28-2024, 06:04 AM
(This post was last modified: 05-28-2024 06:06 AM by ELye.)
(05-22-2024 01:26 AM)Allen Wrote: Appears to be a NO-OP. You are absolutely right. See attached jpg. |
