Correct o-ring size for HP-65 and HP-67 card readers
05-29-2024, 04:03 PM
Hello Everyone
first of all sorry for not contributing since a long time, but we have been busy on too many things ...
The quality of the contents have been constantly growing
so thanks for keeping alive this wonderful group !
Also, let me amend in advance because I'm pretty sure it has been asked and answered before,
I have however done some research but couldn't find anything, so here I'm asking ...
What's the best size ID/OD of the o-rings when fixing a gummy card reader ?
Thank you very much in advance !
Take care everyone !!
Edoardo & Alberto
05-29-2024, 05:19 PM
RE: Correct o-ring size for HP-65 and HP-67 card readers
Hi Alberto,
Welcome back, great to hear from you again.
Searching the articles you can find an article on the HP-82104A O-ring size.
https://www.hpmuseum.org/cgi-sys/cgiwrap...gi?read=57
Searching the net for "o-ring s006" will give (for me in Germany at least)
https://www.lesker.com/flanges/silicone-...art/o-s006
where you find the exact measuring including mm and inches.
Buy from the seller of your confidence :-).
Andi
05-29-2024, 06:50 PM
for a possible US based alternative, last year I repaired the card reader in my 41, after reading many of the articles in the forum I went with the flexible tubing approach instead of the o-rings, and it worked well for me, granted, a lot of more experienced people here prefer the o-rings, but the clincher for me was the availability of the right size tubing.
I got it from McMaster-Carr, link to the item in question below
https://www.mcmaster.com/catalog/130/161/9627T13
06-03-2024, 04:24 PM
(05-29-2024 06:50 PM)born2laser Wrote:  for a possible US based alternative, last year I repaired the card reader in my 41, after reading many of the articles in the forum I went with the flexible tubing approach instead of the o-rings, and it worked well for me, granted, a lot of more experienced people here prefer the o-rings, but the clincher for me was the availability of the right size tubing.
Thank you very much for your reply,
may I ask you why not using the 9627T14 ?
It looks more close to the o-ring specs
Let me know and thank agains !
Edoardo & Alberto
06-03-2024, 04:26 PM
(05-29-2024 05:19 PM)AndiGer Wrote:  Hi Alberto,
Andi
Thanks Andy, I have two bags of two different sizes, and can't really distinguish them
I'll give it a try to the 006, but I guess I have always used something slightly small ...
Thanks again !
Edoardo & Alberto
06-03-2024, 06:15 PM (This post was last modified: 06-03-2024 06:18 PM by AndiGer.)
Hi Alberto,
The one‘s I bought and several times successfully used is 006
They are listed 2.90 x 1.78 mm.
First ID, second thickness
Good luck
Andi
06-04-2024, 01:51 AM
(06-03-2024 04:24 PM)albertofenini Wrote:
(05-29-2024 06:50 PM)born2laser Wrote:  I got it from McMaster-Carr, link to the item in question below
That is indeed true, I had not noticed. I vaguely remember that somebody in the forum gave the dimensions of tubing they had used and I based my choice on that, it worked for me so I did not question it. If I had noticed at the time I would probably have ordered both!
One thing to note is that the tubing fits snuggly on the motor axis, and the ID of the o-ring is smaller, so it probably stretches more and the resulting OD is about the same (I am guessing wildly here).
Juan
