HP-50g - Define functions with matrices inside
05-31-2024, 12:50 AM
Just buy a HP-50g, so i'm still a newbie here.
I need to define some functions with matrices inside, but it seem impossible. An example: DEFINE(A(M,R)=M*[[COS(R),1][1,COS(R)]]) or anything that contains a matrix inside, like: DEFINE(A(B)=B*[[1,1][1,1]]) I'm writing the matrices with matrix writer. Algebric mode The "define" works well with every operation so far, but when I try to put any matrix inside, it shows "Bad argument type" error. Thanks and sorry for the newbie question! |
05-31-2024, 02:52 PM
RE: HP-50g - Define functions with matrices inside
I couldn't make it work in ALG-mode either but I have to say I'm not used to ALG-mode.
But it's rather easy to create a small RPN-program that takes two arguments (M and R) from the stack and does what you want. Not sure how to program that in ALG-Mode though. Program listing in RPN \<< \-> M R \<< [[ 'COS(R)' 1 ][ 1 'COS(R)' ]] M * \->NUM \>> \>> 'A' STO // store the program in A How to use it in RPN-mode: 1.5 // M 30.0 // R [A] // with softmenu, press [VAR] and [NXT] till you see [A] Output: [[ 1.2990 1.5000 ][ 1.5000 1.2990]] But once created it will work in ALG-mode as well: '->NUM(A(1.5,30.0))' // ->NUM from the cat menu HTH Roman |
