Battery drain in an HP-4CV
06-13-2024, 09:05 AM
Waht would drain the atteries (say in 4 hours) on an HP-41CV??
Namir
06-13-2024, 11:16 AM
RE: Battery drain in an HP-4CV
(06-13-2024 09:05 AM)Namir Wrote:  Waht would drain the atteries (say in 4 hours) on an HP-41CV??
Many things come into mind:
First: Current leakage somewhere.
Maybe between the zebra strips and CPU-board, or the I/O block and the kbd pcb,
a defective LCD module solder path, or even a defective CPU board.
-- Ray
06-13-2024, 11:36 AM
Hi Namir, I had such a problem many years ago with a bought calculator on TAS, and I remind that somebody, here, suggested it could be due to a defective capacitor; actually I never knew the cause 'cause I sent back the calculator. So I'm curious me too to know what could be the issue on your calculator.
06-13-2024, 11:46 AM
Namir
Are you saying a brand new set of good quality (e.g. Energizer) N cells is depleted in 4 hours in a 41CV just sitting on the table? If so, it must get awfully warm, as that energy has to go somewhere. Or do you mean 4 hours of heavy execution time?
06-14-2024, 12:25 AM
Namir
Not sure what the calculator user meant by 4 hours (whether of heavy use or not). He said he was testing his Stress module that he plugged in.
Namir
