Bought a used SPECO ocilloscope - worth keeping?
06-24-2024, 10:53 PM
I was in a thrift store that happened to have a SPECO Model FS-4820 Oscilloscope for sale. The woman running the shop said "I have no idea what it is. But the price is $5." I told my wife about it during dinner out, and she said that I should buy it even though it has only a power cord, and I know zero about how to operate it. So for $5, I made a donation (in my opinion).
In searching the internet for information about it, I found out that it's identical to the AWS Model 620C oscilloscope. So I downloaded that manual for that brand and model. Does anyone know if this unit is worth plugging and testing without any accessories such as probes? Thank you! Joe |
06-25-2024, 12:59 AM
RE: Bought a used SPECO ocilloscope - worth keeping?
I have that exact AWS 'scope, and it was a good one until it developed problems with the switches and they proved to be pretty much inaccessible to get contact-cleaner spray into them. I also have another analog 'scope that's faster, but it has the same problem. I had another nice, compact one that was great until the power supply went down, and everything was so tightly packed into this compact unit that I couldn't figure it out, and the manufacturer no longer supported it. Then my employer gave me an Agilent digital 'scope that's far more capable, but I tell ya—that thing is not one bit user-friendly—it's user hostile! I can't even get some basic displays from it. It thinks it knows better what settings I want, and it won't just do what I tell it to. (And yes, I've read the entire manual, twice.) After I wrote about this on other forums, other people said that yeah, that's the way Agilent oscilloscopes are. At my last place of work, I had a nice Philips DSO that was very easy to use. It had an analog mode too, but I never had a need to use the analog mode. I'm about ready to buy another new but old-fashioned analog 'scope before they're totally gone. Even for digital work, I can nearly always get things to repeat well enough to see them on an analog 'scope.
Oh, one thing about oscilloscopes: They're not much good without a good set of probes; and good probes are not cheap. There's a lot more to them than meets the eye, and even the cable is not regular coax. http://WilsonMinesCo.com (Lots of HP-41 links at the bottom of the links page, at http://wilsonminesco.com/links.html#hp41 ) |
06-25-2024, 10:55 AM
(This post was last modified: 06-25-2024 10:58 AM by Maximilian Hohmann.)
(06-25-2024 12:59 AM)Garth Wilson Wrote: Oh, one thing about oscilloscopes: They're not much good without a good set of probes; and good probes are not cheap. There's a lot more to them than meets the eye, and even the cable is not regular coax. Yes, of course. But just to test that oscilloscope I would suggest to buy the cheapest probe that can be found on eBay (I paid 1 Euro for my cheapest one, probably one percent of what it cost when new). My analog scope is long gone, since many years a use a cheap(ish) Chinese clone of a digital Tektronix oscilloscope. Other than the mediocre LCD screen it is perfectly up to what I need it for. For me the two big advantages are the lack of a power cord - it is battery operated - and the UBS connection by which the data can be uploaded to a computer for further processing. If I ever buy another one it will be one of those small boxes that you connect via USB and run from your notebook. Regards Max |
06-25-2024, 05:47 PM
It's starting to sound like this would be a good piece of older test gear that I can put on the the "FREE" table at the next VCF West in Orange, California (if there is one!).
Thank you for the replies! Joe |
06-25-2024, 11:39 PM
(This post was last modified: 06-25-2024 11:45 PM by Ren.)
I have 5 o-scopes, but I haven't used any in a while.
I think it would be quickly snapped up at the VCF, and you could probably get your $5 back! Edit: If you are a "stereo" buff, you might want to keep it and have it display the waveforms of the audio signal you're listening to, just adding a bit of "bling" to your gear. At those frequencies, you can get by without probes, just some coax and BNC. 10B, 10BII, 10C, 11C, 12C, 14B, 15C, 16C, 17B, 18C, 19BII, 20b, 22, 25, 29C, 35, 38G, 39G, 39gs, 41CV, 48G, 97 |
