single_inter does not find intersection
09-28-2014, 10:33 AM
Hi all!
Working with the Geo App on graphically estimating working points, voltages, gains and the like for a tube shortwave HF-Amp. (BTW, great App that tends to become one of my all time favorites - thanks a lot guys!)
I defined some plotfunc's of the form plotfunc(a*ln(x)+b). Examples:
GB plotfunc(1.301*ln(x)+3.406
GC plotfunc(0.9718*ln(x)+2.524
These functions get plotted without any problems.
Then I defined a point:
GE point(40,0)
It also gets plotted fine.
Then an element of GC as:
GG element(GC,20)
Goes well too.
Then the line through GE and GG as:
GH line(GE,GG)
Everything fine yet.
Now I try to find the intersection of GH with GB using:
GI single_inter(GH,GB)
The App cannot find that point. (It does not work using single_inter(GH,GB,GG) or single_inter(GH,GB,GE) either.)
But the CAS can readily nsolve this and get the x-coordinate of the intersection.
So, what is going on? Any suggestions?
Bye,
Nick
09-29-2014, 06:28 AM
RE: single_inter does not find intersection
You´re right. I followed your steps, and I could not get the intersection point.
By the way, how did you find the solution with nsolve command?. I tried to insert the line ecuation and the LN one, like nsolve([y=-0,2717*x+10,87 y=1,301*LN(x)+3,406],[x,y]) and the sandclock works without answer. I had to soft reset. I used fsolve instead and it worked ok. Something does not work well in this case. Bug?
By the way: where is the fsolve command in the CAS tool boxes? I cannot find it!.
09-29-2014, 06:34 AM
There is indeed a bug. Will be fixed in Xcas (unstable) this week.
09-29-2014, 07:39 AM
(09-29-2014 06:28 AM)akmon Wrote:  You´re right. I followed your steps, and I could not get the intersection point.
Hi!
I just nsolved for x, not for x and y. For example:
nsolve(1,301*LN(x)+3,406-(-0,2717*x+10,87) , x )
which immediately delivers 14.6254232747.
Substituting this value back to either 1,301*LN(x)+3,406 or -0,2717*x+10,87 will give you the y value of 6.89627249626.
Ciao,
Nick
09-29-2014, 07:54 AM
(09-29-2014 06:34 AM)parisse Wrote:  There is indeed a bug. Will be fixed in Xcas (unstable) this week.
OK.
BTW, you mean a bug in single_inter, may I assume? (Or in nsolve, as akmon asked?)
Anyway, I replaced the LN functions with ATAN functions (with different sets of fitted parameters), since I just needed more or less good approximations of measurement series. With ATAN the intersections could be found, and all related calculations could be traced perfectly. (And so at last I know now, why that %&*$-HF-Amp turnes to a HF.. attenuator over 50 MHz. :-))
Thanks and ciao,
Nick
09-29-2014, 08:04 AM
There were 2 problems: one with ln(x) which was replaced by ln(abs(x))+i*arg(x) leading to problems since ln(x) was multiplied by i in the plot parametric equation, another one with mixing exact and numeric data in simplify.
Using atan is safer since it is defined from R to R.
09-29-2014, 09:56 AM
(09-29-2014 08:04 AM)parisse Wrote:  There were 2 problems: one with ln(x) which was replaced by ln(abs(x))+i*arg(x) leading to problems since ln(x) was multiplied by i in the plot parametric equation, another one with mixing exact and numeric data in simplify.
I understand - thank you very much!
Ciao,
Nick
