WTB HP 88014B Battery Pack
06-29-2024, 02:32 AM
I'm looking for the HP 88014B battery pack used in the HP 9114b disc drive, with or without a working battery. I just need the case with electronics but will buy the whole unit, if necessary.
Tom L Cui bono? |
06-29-2024, 07:12 PM
(This post was last modified: 06-29-2024 07:13 PM by Dave Frederickson.)
RE: WTB HP 88014B Battery Pack
Just FYI, an 88014A battery will work in a 9114B drive. And if all you need is the power connector then looking for either model increases your chances of finding a battery.
06-29-2024, 11:02 PM
(06-29-2024 07:12 PM)Dave Frederickson Wrote: Just FYI, an 88014A battery will work in a 9114B drive. And if all you need is the power connector then looking for either model increases your chances of finding a battery. Thanks but all I find when I look up 88014A is batteries. I have the battery, I just need the 88014B case and regulator circuit board with its connectors. Tom L Cui bono? |
06-30-2024, 01:29 PM
I don't think I explained things very well.
Either an 88014A or 88014B Battery Pack will work in a "B" drive. You increase your chances of finding a battery pack by looking for "A" Battery Packs as well. |
