HP 88014B Battery Pack AC Adapter Connector
06-29-2024, 03:59 AM
Is there a standard part I can order to replace the connector in the HP 88014B battery pack that the AC adapter plugs into? It has two gray wires coming from it internally. The part is a panel mount that snaps into a hole in the back of the battery box case. The wires have come disconnected from it and in trying to solder them back on, I've ruined the plastic housing the lugs are mounted in.
Tom L Cui bono? |
06-29-2024, 06:56 PM
(This post was last modified: 06-29-2024 07:05 PM by Dave Frederickson.)
RE: HP 88014B Battery Pack AC Adapter Connector
On the 71B, for example, that is a pin adapter plate, P/N 00071-60006, that slides into a slot in the 71's case. It would appear that the connector is custom, however there may be a standard version of it.
