PARTIAL FRACTION DECOMPOSITION for HP-67/97 Calculation of residuals
07-10-2024, 04:41 PM
Hi everyone,
here I am again to introduce you to my new program for HP-67/97 "Residues" for the calculation of the residues of a function F(s)=N(s)/D(s) with N(s) and D(s) polynomials in s with Degree of D(s) greater than N(s). The calculation of the residues is done by decomposition into simple fractions. The file,"Partial Fraction Decomposition.PDF",contained in the attachment in the RESIDUES folder (HP6797_RESIDUES.ZIP), illustrates how to calculate and use the Residues of the Function F(s). In addition to the manual and the aforementioned file, the folder contains as usual the listing of the program "HP6797 RESIDUES.PDF", the card containing the program in format with the .hp97 extension which can be used with emulators for HP-67 and HP-97 by LimpidFox and a "POLYROOTS" folder where there are as many listings "POLYROOT1.PDF", "POLYROOT2.PDF", again for hp-67/97 and an "INSTRUCTIONS" folder containing the instructions for using the calculation program of roots of polynomials up to degree 18 By Mr. Eric Marchal (Belgium). The manual contains examples of use Thanks for the attention Plore90 |
