WTB: CASIO AD-4175 AC Adaptor
07-25-2024, 12:31 AM
Looking for a working CASIO AD-4175 AC adapter.
Please PM me if you have one for sell. Thx! |
07-29-2024, 05:53 PM
(This post was last modified: 07-30-2024 04:27 PM by kknicker.)
RE: WTB: CASIO AD-4175 AC Adaptor
I assume you are looking for the AC adapter for the Casio PB-2000C I sent you. The original AC adapter seems hard to come by.
It appears the Casio AD-4175 was used by the PB-2000C, MX-10, MX-15, and MX-101 computers, so you may have some luck searching in relation to those computers also. Here is a post with information about the Casio AD-4175 AC adapter if you want to look for a modern AC adapter that may work. https://electronics.stackexchange.com/qu...2000c-mean Here is one from Jameco that may work if the barrel is the correct size. It looks like Casio AD-4175 AC adapter is center negative, so make sure whatever you get also has that polarity. https://www.jameco.com/z/DDU090100C2550-...64929.html Good luck, -Kevin |
08-01-2024, 02:18 AM
Thanks for the info., Kevin !
I am still researching on the output voltage. Is it 7V or 8V ? I assume 1Amp should be plenty current for it. |
08-01-2024, 09:34 PM
(07-25-2024 12:31 AM)fy789 Wrote: Looking for a working CASIO AD-4175 AC adapter. Unless you're a collector who needs all-Casio parts, you can use any adapter that has the same specs as the 4175: DC out: 7V, 800mA Jack: about 3/16", center negative Tom L Cui bono? |
