(12C) Permutation & Combination revisit
07-25-2024, 08:36 AM
This program calculate the Permutation nPr and Combination nCr
using the HP-12C with this program it can be use to do arithmetic calculation.
Usage:
For Permutaion make sure program is at the beginning [f] PRGM
for Combination start program at line 16 [g] GTO 16
nPr is Permutation input n [ENTER] r [R/S] display answer
nCr is Combination input n [ENTER] r [R/S] display answer
Both for n > r
Example: FIX 0
11P6 - 8P5 = ?
[f] PRGM
11 [ENTER] 6 [R/S] display 332640
8 [ENTER] 5 [R/S] display 6720 [-] display answer 325920
12C5 - 9P7 = ?
[g] GTO 16
12 [ENTER] 5 [R/S] display 792
[f] PRGM
9 [ENTER] 7 [R/S] display 181440 [-] display answer -180648
8P3 + 6C3 - 5P3 = ?
[f] PRGM
8 [ENTER] 3 [R/S] display 336
[g] GTO 16
6 [ENTER] 3 [R/S] display 20 [+] display 356
[f] PRGM
5 [ENTER] 3 [R/S] display 60 [-] display answer 296
Program:
Quote:01 X<>Y
02 n!
03 LSTx
04 X<>Y
05 R↓
06 X<>Y
07 -
08 n!
09 X<>Y
10 R↓
11 ÷
12 X<>Y
13 R↓
14 GTO 00
15 R/S
16 X<>Y
17 n!
18 LSTx
19 X<>Y
20 R↓
21 X<>Y
22 -
23 LSTx
24 n!
25 X<>Y
26 n!
27 x
28 X<>Y
29 R↓
30 ÷
31 X<>Y
32 R↓
33 GTO 15
Gamo 7/2024
07-28-2024, 10:57 AM
RE: (12C) Permutation & Combination revisit
The same, just a little shorter:
01-       34 : x<>y
02-    43  3 : n!
03-       34 : x<>y
04-    43 36 : LSTx
05-       34 : x<>y
06-       30 : -
07-    43  3 : n!
08-       10 : ÷
09- 43,33 00 : GTO 00
10-       31 : R/S
11-       34 : x<>y
12-       36 : ENTER
13-    43  3 : n!
14-       33 : R↓
15-       34 : x<>y
16-       30 : -
17-    43 36 : LSTx
18-    43  3 : n!
19-       34 : x<>y
20-    43  3 : n!
21-       20 : ×
22-       34 : x<>y
23-       33 : R↓
24-       10 : ÷
25-       34 : x<>y
26-       33 : R↓
27- 43,33 10 : GTO 10
Now you have to GTO 11 to calculate Combination nCr.
07-28-2024, 04:29 PM (This post was last modified: 08-07-2024 05:38 PM by C.Ret.)
Dear friends,
These codes are interesting, but they are actually two codes in one.
If we are allowed to use a memory register and without changing the way we enter \(n\) and \(k\) in the stack, it is possible to make a shorter code.
Indeed \( P(n,k) = \frac{n!}{(n-k)!}\) and \(C(n,k)=\frac{n!}{(n-k)! \cdot k!}\) thus \(C(n,k)=\frac{P(n,k)}{k!}\).
The idea is that instead of typing a GTO xx to start the calculation of the combinations from scratch, it is enough to press R/S when the number of Permutations \(P(n,k)\) is displayed to continue and terminate the computation of the Combinaisons \(C(n,k)\).
So I propose the following code:
01-    44 0  STO 0
02-      33  R↓
03-   43  3  n!
04-   43 36  LSTx
05-    45 0  RCL 0
06-      30   -
07-   43  3  n!
08-      10   ÷
09-      31  R/S
10-    45 0  RCL 0
11-43,33 07  GTO 07
P.S.: It is possible to save an instruction by changing the way \(n\) and \(k\) are entered in the stack (but this make a lot of R/S - this version is the easier to use.
Usage:
Permutations:
Restart from start : [ f ] [ Prgm ]
Enter \(n\) and \(k\) : n [ENTER] k
Press [R/S] to run the code and get the # of permutations \(P(n,k)\)
Combinaisons:
Press [R/S] to run the code and press [R/S] a second time when Permutations are displayed to get the # of Combinaisons \(C(n,k)\).
Example:
8P3 + 6C3 - 5P3 = ?
8 [ f ][ PRGM ] 3 [R/S] display 336
6 [ f ][ PRGM ] 3 [R/S] display 120 [R/S] display 20 [+] display 356
5 [ f ][ PRGM ] 3 [R/S] display 60 [-] display answer 296.
EDIT: 24-AOUT-07 Typo in key-codes of RCL 0. Mnemonic Rdn replace by R↓ see folling posts.
07-28-2024, 05:57 PM
Excellent code. Most efficient. Thanks!
08-04-2024, 03:09 PM (This post was last modified: 08-04-2024 04:08 PM by AnnoyedOne.)
IMHO "Rdn" probably should be "ROLL". However the keycode (33) is correct.
The "RCL 0" keycodes should be "45 0" not "44 0".
The code works in my HP HP-12C PC (v1.2 11/29/2012) & Android (v1.6.5 5/26/2015) "virtual calculators". I don't have a HP-12C.
HP-15C (2234A02xxx), HP-16C (2403A02xxx), HP-15C CE (9CJ323-03xxx), HP-20S (2844A16xxx), HP-12C+ (9CJ251)
08-07-2024, 05:32 PM (This post was last modified: 08-07-2024 05:39 PM by C.Ret.)
(08-04-2024 03:09 PM)AnnoyedOne Wrote:  IMHO "Rdn" probably should be "ROLL". However the keycode (33) is correct.
Thanks you to point out this two inaccuracies.
I correct the key-codes of the RCL operations in my post.
Rdn stand for Roll-Down, I may perhaps have use R↓ instead?
08-07-2024, 05:49 PM
(08-07-2024 05:32 PM)C.Ret Wrote:  I may perhaps have use R↓ instead?
No worries. I didn't know that the forum supported that (hence ROLL). I know my PC text editors don't.
