Looking for HP-94 development software
08-18-2024, 12:09 PM
I have found a HP-94 calculator but the development software (no matter how awkward to install, or what kind of host it requires) is nowhere to be found. Asking for help in this area: anyone can provide a source? Also, I am interested in some ROM board(s) if possible. Thank you.
08-18-2024, 03:46 PM
RE: Looking for HP-94 development software
HP-94 D/E/F Handheld Industrial Computer
Sylvain Côté
08-18-2024, 03:54 PM
Thank you Sylvain. I need now to get a DOS computer it seems.
(08-18-2024 03:46 PM)Sylvain Cote Wrote:  HP-94 D/E/F Handheld Industrial Computer
08-18-2024, 03:58 PM
(08-18-2024 03:54 PM)abalasa Wrote:  Thank you Sylvain. I need now to get a DOS computer it seems.
...or use Dosbox.
https://www.dosbox.com/
Or you can use FreeDOS in a VirtualBox VM.
https://www.freedos.org/
https://www.virtualbox.org/
(Not affiliated with any of the organisations, just a happy user of their products)
DosBox makes it easier than VirtualBox to get at the files you're working on.
Current daily drivers: HP-41CL, HP-15C, HP-16C
08-18-2024, 04:01 PM
Search for vdos, or dosbox, as a means to run a dos environment in windows 10, or 11.
There are similar for Linux, and probably Apple machines as well.
No guarantee in suitability for your needs. ?
08-18-2024, 04:43 PM
@Alex - You probably will need a real (Pentium-II or earlier) DOS system just to convert the .td0 disk images to real media; don't underestimate how tedious and annoying this part alone can be. It is feasible to do so using some modern conversion utilities, but still a non-trivial undertaking.
