HP-15C time calculating program
08-29-2024, 05:48 PM
I have a thermal cooking process for canned salmon that needs to be timed for a specific amount of time.
The process time is 4 hrs and 34 min. I have written a program that calculates the cook time correctly but displays the calculated process time in 24 hour format ie. 12:00 start time and 4 hrs and 34 min later it is done cooking at 4:34 but displays 16:34. I need a subroutine that takes the integer and subtracts 12 from it if the integer is greater than 12 and displays the calculation in 12 hour format. Here is my program that calculates the process time in 24 hour format. F LBL A G>H STO 3 4.57 (= 4 hrs 34 min in decimal hours) ENTER RCL 3 + F >HMS Sto 2 G RTN Any help would be much appreciated |
08-30-2024, 03:42 AM
RE: HP-15C time calculating program
Something like this?
Code: 001 { 42 21 11 } f LBL A |
08-30-2024, 12:50 PM
from step 10 onwards:
Code: 010 { 1 } 1 Cheers, Werner 41CV†,42S,48GX,49G,DM42,DM41X,17BII,15CE,DM15L,12C,16CE |
08-30-2024, 02:25 PM
Except that for 8 the result should probably be 12.3400 and not 0.3400.
08-30-2024, 04:06 PM
(This post was last modified: 08-30-2024 04:54 PM by C.Ret.)
Yes, indeed it is very tempting to use a modulo of 12 to simplify the code.
But a modulo of 12 returns numbers between 0 and 11. Here, we need an interval between 1 and 12. A small shift can do the trick in a minimum of steps: Code: 001-42,21,11 f LBL A f FIX 4 12 STO 0 for 12-O'Clock systems (Alternatively 24 STO 0 for 24hr dial systems). 1 STO 1 for 1 - 12 hours range (Alternatively 0 STO 1 for 0-23 range display). 4.3400 g →H STO f I to get 4 h 34 min 00 second reacting length time. Usage: Enter starting time and press f A, the HP-15C display the ending time. Examples: Typical 12-hour clock system: 12 STO 0, 1 STO 1, 4.34 g →H STO f I 7 f A ⇒ 11.3400 7.30 f A ⇒ 12.0400 8 f A ⇒ 12.3400 8.23 f A ⇒ 12.5700 8.3015 f A ⇒ 1.0415 9 f A ⇒ 1.3400 9.4523 f A ⇒ 2.1923 11.15 f A ⇒ 3.4900 12.05 f A ⇒ 4.3900 |
08-30-2024, 04:13 PM
I *knew* I had replied too quickly, and there had to be a catch!
09-04-2024, 06:17 PM
(This post was last modified: 09-06-2024 03:50 PM by lomchivok.)
(08-30-2024 03:42 AM)Thomas Klemm Wrote: Something like this?Thank you Thomas, Werner and all that have helped. Thomas and Werner's program will work the best for me in that I have 4 different container sizes in our Alaska plant...1/4 lb, 1/2 lb, 1 lb and 4 lb... that have their own scheduled process time. I need a program for each process and this allows me to assign a program letter to each process and just change the process time within the program. I don't want the operator to do anything other than enter the time the process starts to alleviate any confusion. A 1 minute short process generates a ton of paperwork and possibly a re-process if too short. All of our thermal process records are individually inspected by USFDA and must be correct or corrected sufficient to meet their guidelines. It's not difficult to do the math on paper but when an operator is working in a 90 degree steam saturated environment for 18 hours, mistakes start to happen that we cannot afford. We have 8 retorts for thermal processing. Each retort load of 1/4 lb cans holds 28,000 cans...mistakes can be costly. I did write a program for this in the mid 80's but lost the program and haven't used this calculator in 30 years...it's slowly coming back to me now. Once again thanks to all that have helped. |
