emulate xcas simplify integrate on hp prime g2
09-09-2024, 08:11 PM
Is there a way on the prime to duplicate:
xcas: simplify(integrate(x^2,x,0,x)=1000)
to get the result:
(a^3)/3 = 1000
I can do translate the following xcas expression
fsolve(integrate(x^2,x,0,x)=1000)
to get
14.4224957031
which is an approximation for
10 * 3^(1/3)
Thanks.
09-09-2024, 11:38 PM
RE: emulate xcas simplify integrate on hp prime g2
Hi, in CAS mode:
solve(integrate(x^2,x,0,t)=1000,t)
See last line in the screenshot
Attached File(s) Thumbnail(s)
09-10-2024, 01:18 AM (This post was last modified: 09-10-2024 02:08 AM by Liamtoh Resu.)
Thanks for your reply.
I'm getting 14.4224957031 inside the curly braces.
Perhaps my CAS settings are different.
Did you get the 't' from the [alpha divide T] or from the [x t theta n button] ?
Thanks.
--- edit
I changed the CAS settings CHK the Exact setting and got the same answer you did.
Thank you very much.
--- edit
I have prepared a small pdf file to reflect the nature of this post.
Attached File(s)
.pdf  hp_prime_g2_solve_integrate_example.pdf (Size: 30.5 KB / Downloads: 10)
09-10-2024, 02:12 AM
the 't' came from the alpha divide t
Previous image was a screen capture from the PC application. Now I'm attaching photos from the physical calculator with the solve command and with my CAS settings. Hope it helps.
