Problem with 2nd order polynomial
Yesterday, 08:19 AM
(This post was last modified: Yesterday 09:05 AM by ktomp.)
Hello everyone,
I got an exam the other day and to my surprise my HP prime (G1 hardware) failed to solve a 2nd order polynomial (a*x^2+b*x+c = 0) with the following coefficients: a = 30188156.0038281 b = -12497373621.6526 c = 1058636761186.350 I was in CAS mode and tried using the Solve, Zeros, Numerical Solve but only got empty brackets as a result (like []). Same thing happens even with the latest update of 2024/09. It's probably due to the fact that the coeffecients of the polynomial where quite large numbers, cause when I divided everything with the "a" coefficient and the polynomial became x^2+(b/a)*x+(c/a) all the functions managed to find the roots correctly. Could this be a bug? Many thanks for your help |
Yesterday, 01:16 PM
(This post was last modified: Yesterday 08:37 PM by Patocuy.)
RE: Problem with 2nd order polynomial
Hi.
I used proot and solve and got the same solutions with both functions, perhaps solve needs to know which variable you are solving for. UPDATE Now I used the same syntax as you, without specifying the variable to solve for and got the same solutions as before. You could use purge(x) to be sure that x has no value assigned and check your CAS settings, I have attached mine so you can compare. Regards |
Today, 06:58 AM
Hi, thanks for trying to help me out.
I only managed to get solutions with proot() function. Solve() won't return solutions regardless of the syntax. I even purged x just to be sure, but to no avail. |
Today, 02:53 PM
(This post was last modified: Today 03:03 PM by C.Ret.)
Hi guys!
Just look at this and compare: What are your conclusions or assumptions? Are they the same as the one I just made? How did the CAS-solve statement work out numerically compared to other specific and only numeric functions? Did you understand what happened with CAS-solve when an interval is given for the numerical variable x? Why this works in the first case? Hope this helps you a little. And that the prankster HP Prime didn't ruin all of ktomb 's hopes of passing his exam! |
