Jump forward and back a view
09-27-2024, 06:24 AM
Hello everyone, I need your help again.
I would like to scroll back and forth between the last two subprograms "Output" and "Graphics" in the listed program. In both outputs you can also jump to the beginning of the program or end the program. Both via the touch display. I just can't get from the "graphics" output back to the "output" of the calculation!
Greetings Heino
System();Beton();Berechnung();Ausgabe();
Tabelle();Grafik();
Md1;Nd1;h;b;cnom;∅Büg;∅Bew;d1;kd;
A1;A2;A3;A4;A5;A6;A7;A8;A9;A10;
KS1;AS1;XI1;ZETA1;BET1;
W1;N1;I1;
xh1;z1;Fsd;
EXPORT Bemessung()
STARTVIEW(-1);
INPUT({{Md1,[0],{30,17,0}},
{Nd1,[0],{30,17,1}},
{h,[0],{30,17,2}},
{b,[0],{30,17,3}},
{cnom,[0],{77,17,0}},
{∅Büg,[0],{77,17,1}},
{∅Bew,[0],{77,17,2}}},
"Ermittlung von kd",
{"MEds [kNm]","NEd [kN]","h [cm] ","b [m] ","cnom [cm] ","∅Büg [mm]","∅Bew [mm]"},
{"Bemessungsmoment","Zugkraft","Höhe des Betonquerschnittes","breite des Betonquerschnittes [m]","Betondeckung [cm]","Bügeldurchmesser [mm]","Bewehrungsdurchmesser [mm]"});
d1:=h-cnom-∅Büg/10-∅Bew/20;
kd:=d1/√((Md1/b));
Tabelle();
Tabelle()
A1:={"1.54","1.57","1.60","1.62","1.65","1.69","1.73","1.77","1.82","1.86","1.91","1.97","2.03","2.11","2.21","2.30","2.43","2.60","2.81","3.10","3.40","3.82","4.55","6.12","11.13"};
A2:={"1.38","1.40","1.43","1.45","1.48","1.51","1.54","1.58","1.63","1.67","1.71","1.76","1.82","1.89","1.97","2.06","2.18","2.32","2.51","2.78","3.04","3.42","4.07","5.47","9.95"};
A3:={"1.26","1.28","1.30","1.33","1.35","1.38","1.41","1.44","1.49","1.52","1.56","1.61","1.66","1.72","1.80","1.88","1.99","2.12","2.29","2.53","2.77","3.12","3.71","5.00","9.09"};
A4:={"1.17","1.19","1.21","1.25","1.28","1.30","1.34","1.38","1.41","1.44","1.49","1.54","1.54","1.59","1.67","1.74","1.84","1.96","2.12","2.35","2.57","2.89","3.44","4.63","8.41"};
A5:={"1.09","1.11","1.13","1.15","1.17","1.19","1.22","1.25","1.29","1.32","1.35","1.39","1.44","1.49","1.56","1.63","1.72","1.84","1.99","2.20","2.40","2.70","3.22","4.33","7.87"};
A6:={"1.03","1.05","1.07","1.08","1.10","1.13","1.15","1.18","1.21","1.24","1.27","1.31","1.36","1.41","1.47","1.53","1.62","1.73","1.87","2.07","2.26","2.55","3.03","4.08","7.42"};
A7:={"0.98","0.99","1.01","1.03","1.05","1.07","1.09","1.12","1.15","1.18","1.21","1.24","1.29","1.33","1.40","1.46","1.54","1.64","1.78","1.96","2.15","2.42","2.88","3.87","7.04"};
A8:={"3.09","3.04","2.99","2.95","2.91","2.87","2.83","2.79","2.75","2.72","2.69","2.66","2.63","2.60","2.57","2.54","2.51","2.48","2.45","2.42","2.40","2.38","2.36","2.34","2.32"};
A9:={"0.617","0.585","0.555","0.530","0.504","0.477","0.450","0.422","0.393","0.371","0.350","0.325","0.302","0.277","0.2507","0.227","0.201","0.174","0.147","0.120","0.104","0.087","0.069","0.048","0.025"};
A10:={"0.743","0.757","0.769","0.780","0.790","0.801","0.813","0.824","0.836","0.846","0.854","0.865","0.875","0.855","0.896","0.906","0.916","0.927","0.939","0.950","0.958","0.966","0.975","0.983","0.991"};
KS1:=A8;
XI1:=A9;
ZETA1:=A10;
Beton();
//A1:={"11.13","6.12","4.55","3.82","3.40","3.10","2.81","2.60","2.43","2.30","2.21","2.11","2.03","1.97","1.91","1.86","1.82","1.77","1.73","1.69","1.65","1.62","1.60","1.57","1.54"};
//A2:={"9.95","5.47","4.07","3.42","3.04","2.78","2.51","2.32","2.18","2.06","1.97","1.89","1.82","1.76","1.71","1.67","1.63","1.58","1.54","1.51","1.48","1.45","1.43","1.40","1.38"};
//A3:={"9.09","5.00","3.71","3.12","2.77","2.53","2.29","2.12","1.99","1.88","1.80","1.72","1.66","1.61","1.56","1.52","1.49","1.44","1.41","1.38","1.35","1.33","1.30","1.28","1.26"};
//A4:={"8.41","4.63","3.44","2.89","2.57","2.35","2.12","1.96","1.84","1.74","1.67","1.59","1.54","1.49","1.44","1.41","1.38","1.34","1.30","1.28","1.25","1.23","1.21","1.19","1.17"};
//A5:={"7.87","4.33","3.22","2.70","2.40","2.20","1.99","1.84","1.72","1.63","1.56","1.49","1.44","1.39","1.35","1.32","1.29","1.25","1.22","1.19","1.17","1.15","1.13","1.11","1.09"};
//A6:={"7.42","4.08","3.03","2.55","2.26","2.07","1.87","1.73","1.62","1.53","1.47","1.41","1.36","1.31","1.27","1.24","1.21","1.18","1.15","1.13","1.10","1.08","1.07","1.05","1.03"};
//A7:={"7.04","3.87","2.88","2.42","2.15","1.96","1.78","1.64","1.54","1.46","1.40","1.33","1.29","1.24","1.21","1.18","1.15","1.12","1.09","1.07","1.05","1.03","1.01","0.99","0.98"};
//A8:={"2.32","2.34","2.36","2.38","2.40","2.42","2.45","2.48","2.51","2.54","2.57","2.60","2.63","2.66","2.69","2.72","2.75","2.79","2.83","2.87","2.91","2.95","2.99","3.04","3.09"};
Beton()
STARTVIEW(6,1);
CHOOSE (N1,"Betongüte",{"C 20/25","C 25/30","C 30/37","C 35/45","C 40/50","C 45/55","C 50/60","Ende"});
IF N1==1 THEN W1:=A1; BET1:="C 20/25"; END;
IF N1==2 THEN W1:=A2; BET1:="C 25/30"; END;
IF N1==3 THEN W1:=A3; BET1:="C 30/37"; END;
IF N1==4 THEN W1:=A4; BET1:="C 35/45"; END;
IF N1==5 THEN W1:=A5; BET1:="C 40/50"; END;
IF N1==6 THEN W1:=A6; BET1:="C 45/55"; END;
IF N1==7 THEN W1:=A7; BET1:="C 50/60"; END;
IF N1==8 THEN END;
Berechnung();
Berechnung()
REPEAT
I1:=I1+1;
UNTIL (EXPR(W1(I1)))>kd or kd>(EXPR(W1(25))) or kd<(EXPR(W1(1)));
RECT_P(0,0,320,220,RGB(0,255,255));
IF kd>(EXPR(W1(25))) THEN KS1:=EXPR((KS1(25))); END;
IF kd<(EXPR(W1(1))) THEN KS1:=EXPR((KS1(1))); END;
AS1:=(EXPR(KS1(I1-1)))*Md1/d1+Nd1/43.5;
Ausgabe();
Ausgabe()
LOCAL m,m1,mx,my;
LOCAL Ende,Weiter,Zurück;
RECT_P(0,0,320,35,RGB(0,34,174));//BLAU
TEXTOUT_P("erf.As nach dem kd-Verfahren",30,5,5,RGB(255,255,255));
TEXTOUT_P("Betongüte",10,40,4);
TEXTOUT_P(":",85,40,4);
TEXTOUT_P(BET1,93,40,4);
TEXTOUT_P("cnom",180,40,4);
TEXTOUT_P(":",220,40,4);
TEXTOUT_P(ROUND(cnom,2)+" cm",240,40,4);
TEXTOUT_P("MEd",10,70,4);
TEXTOUT_P("=",50,70,4);
TEXTOUT_P(ROUND(Md1,2)+" kNm",70,70,4);
TEXTOUT_P("NEd",180,70,4);
TEXTOUT_P("=",220,70,4);
TEXTOUT_P(ROUND(Nd1,2)+" kN",240,70,4);
TEXTOUT_P("h",10,95,4);
TEXTOUT_P("=",50,95,4);
TEXTOUT_P(ROUND(h,2)+" cm",70,95,4);
TEXTOUT_P("d",180,95,4);
TEXTOUT_P("=",220,95,4);
TEXTOUT_P(ROUND(d1,2)+" cm",240,95,4);
TEXTOUT_P("kd",10,120,4);
TEXTOUT_P("=",50,120,4);
TEXTOUT_P(ROUND(kd,2),70,120,4);
TEXTOUT_P("ks",180,120,4);
TEXTOUT_P("=",220,120,4);
TEXTOUT_P(EXPR((KS1(I1-1))),240,120,4);
TEXTOUT_P("ξ",10,145,4);
TEXTOUT_P("=",50,145,4);
TEXTOUT_P(EXPR((XI1(I1-1))),70,145,4);
TEXTOUT_P("ζ",180,145,4);
TEXTOUT_P("=",220,145,4);
TEXTOUT_P(EXPR((ZETA1(I1-1))),240,145,4);
RECT_P(0,170,320,240,RGB(0,34,174));//BLAU
TEXTOUT_P("erf.as",85,180,6,RGB(255,255,255));
TEXTOUT_P("=",150,180,6,RGB(255,255,255));
TEXTOUT_P(ROUND(AS1,2)+" cm²",175,180,6,RGB(255,255,255));
DRAWMENU("ENDE","","weiter","","","zurück");
REPEAT
// Get mouse data
REPEAT
m:=MOUSE; m1:=m(1);
UNTIL SIZE(m1)>0;
mx:=m1(1); my:=m1(2);
Ende:=(my≥220 AND my≤319) AND (mx≥0 AND mx≤51);
Weiter:=(my≥220 AND my≤319) AND (mx≥106 AND mx≤160);
Zurück:=(my≥220 AND my≤319) AND (mx≥265 AND mx≤319);
UNTIL (Ende or Weiter or Zurück); // wait for a soft key
//UNTIL (Ende or Weiter); // exit Main loop with "ENDE" or "weiter"
// weiter
IF Weiter THEN Grafik;
//do what you need for weiter
// ENDE
IF Ende THEN STARTVIEW(-1);
//do what you need for ENDE
//Zurück
IF Zurück THEN I1:=0;
Bemessung();
Grafik()
LOCAL m,m1,mx,my;
RECT();
LINE_P(20,20,20,120);
TEXTOUT_P("h",10,60,2);
LINE_P(40,20,40,107);
TEXTOUT_P("d",30,60,2);
LINE_P(60,20,60,55);
TEXTOUT_P("x",50,30,2);
LINE_P(16,20,65,20);
LINE_P(56,55,65,55);
LINE_P(36,107,65,107);
LINE_P(16,120,65,120);
LINE_P(70,142,120,142);
LINE_P(70,125,70,146);
LINE_P(120,125,120,146);
TEXTOUT_P("b",92,130,2);
RECT_P(G0,70,20,120,120,RGB(0,0,0),RGB(180,220,220));
RECT_P(G0,70,20,120,55,RGB(0,0,0),RGB(220,250,220));
RECT_P(G0,75,105,115,110,RGB(0,0,0));
TEXTOUT_P("As₁",90,90,2);
//GRAFIK II
LINE_P(178,20,199,20);
LINE_P(178,20,178,120);
LINE_P(140,120,178,120);
LINE_P(199,20,140,120);
TEXTOUT_P("+",159,97);
TEXTOUT_P("-",181,20);
//GRAFIK III
LINE_P(240,20,240,120);
RECT_P(G0,240,20,265,56,RGB(0,0,0),RGB(220,250,220));
TEXTOUT_P("→",215,93,7);
TEXTOUT_P("Fsd",210,91,2);
TEXTOUT_P("←",270,21,7);
TEXTOUT_P("Fcd",270,19,2);
LINE_P(305,37,305,109);
LINE_P(292,37,308,37);
LINE_P(250,109,308,109);
TEXTOUT_P("z",294,60);
xh1:=EXPR(XI1(I1-1))*d1;
z1:=EXPR(ZETA1(I1-1))*d1;
Fsd:=Md1/(z1/100);
TEXTOUT_P("Druckzonenhöhe",5,155,3);
TEXTOUT_P("x",130,155,3);
TEXTOUT_P("=",155,155,3);
TEXTOUT_P(ROUND(xh1,2)+" cm",175,155,3);
TEXTOUT_P("Innerer Hebelarm",5,175,3);
TEXTOUT_P("z",130,175,3);
TEXTOUT_P("=",155,175,3);
TEXTOUT_P(ROUND(z1,2)+" cm",175,175,3);
TEXTOUT_P("Zugkraft",5,195,3);
TEXTOUT_P("Fsd",130,195,3);
TEXTOUT_P("=",155,195,3);
TEXTOUT_P(ROUND(Fsd,1)+" kN",175,195,3);
REPEAT
// Get mouse data
REPEAT
m:=MOUSE; m1:=m(1);
UNTIL SIZE(m1)>0;
// weiter
// ENDE
//Zurück
IF Zurück THEN Ausgabe;
