(HP-65) Vehicle Braking w ⁄ Wheel Hop
09-29-2024, 01:10 PM
An excerpt from Vehicle Braking w/ Wheel Hop, Master of Science in Mechanical Engineering Thesis, University of Houston, May, 1976, 98 pages
ABSTRACT It is known [4] that brakes perform better "on the road" than is anticipated from laboratory tests, even if the vehicle's wind and rolling resistances are taken into account. The main reason is "burning rubber" on braking. The energy partition between tires and brakes can be readily approximated [3J if the tires run on a perfectly smooth road. A quasi upper bound case is being considered here to show what happens if the tire bounces. It will be shown that a bouncing tire absorbs more energy, but generally stopping times and distances are longer. TABLE OF CONTENTS … APPENDIXES D. DESCRIPTION OF 5 CARD PROGRAM FOR HP-65 PROGRAMMABLE CALCULATOR................ 75 Chapter 1 INTRODUCTION … To find the effects of this additional dynamically in- duced energy loss is the primary objective of this thesis. More specificially, the investigation is directed towards finding orders of magnitude on a simplified model that may be regarded as a quasi upper bound. … A second and separate objective of this thesis is to as- certain the potential of an HP-65 programmable calculator. It is found that the entire program for each braking condition can be put on five memory chips. The calculator proves to be adequate even with its limited nine register memory and 100 step program capability. … Calculations were performed on an HP-65 programmable calculator. Data and program steps were entered on magnetic cards which have a 100 step capacity. Five cards were re- quired for each braking condition. The actual programs used are shown on Hewlett Packard forms in Appendix D. Although the calculator's small memory, nine registers, proved to be somewhat of a problem, in general, the machine was adequate. It has the necessary conditionals, and entering data along with program steps eliminated much key punching. However, more registers and more program steps would have been helpful. The programed calculator was used to determine values for velocity, distance travelled, tire angular velocity, and energy dissipated in the brake and at the tire contact patch at the end of each braking cycle. These points were plotted and joined by smooth curves. The curves do not show in detail how distance, energy, or velocity vary with time within the cycle but give an overall picture through the whole stopping time. Figures 10.2 to 10.5 show in detail how velocity, distance, and energy dissipated in brake and tire vary over a typical braking cycle. … Appendix D DESCRIPTION OF 5 CARD PROGRAM FOR HP-65 PROGRAMMABLE CALCULATOR … HP-65 Program Form Braking Analysis - CARD 1 … HP-65 Program Form Braking Analysis - CARD 3 … HP-65 Program Form Braking Analysis - CARD 3 … HP-65 Program Form Braking Analysis - CARD 4 … HP-65 Program Form Braking Analysis - CARD 5 … BEST! SlideRule |
