(TI-59) Analysis of the Light Curves of Eclipsing Variable Stars
09-29-2024, 04:31 PM
(This post was last modified: 09-29-2024 05:58 PM by SlideRule.)
An excerpt from Analysis of the Light Curves of Eclipsing Variable Stars, Master of Science In Astrophysics Thesis, Physics Dept., University of Alberta, Spring 1984, 212 pages
ABSTRACT Four methods for determining the geometric elements of an eclipsing binary from its light curve are explored in detail. The methods discussed are those of Russell (specifically, the version due to Tabachnik), Kitamura, Kopal (frequency domain approach), and Wood. In each case, the underlying model of an eclipsing binary system is dis- cussed. The various methods of light analysis are then applied to the eclipsing binaries HS Herculis, W Delphini, and HD 219634. The results of each analysis are discussed, and the various methods of analysis are compared with one another. Finally, the relative merits of each model of an eclipsing binary system are considered. Computer programs for the various methods of light curve analysis, along with explanations of their use, are presented in the appendices. REFERENCES Appendix 1 Russell Model Programs and Rectification A1.1 Computer Programs A1.2 An Example, of Rectification Appendix 2 Program for Kitamura's Method Appendix 3 Programs for Kopal's Method Appendix 4 The WINK8 Program Appendix 5 HD219634-observations … The present author has written a program for the TI-59 pro- grammable calculator to use equation (2:17) in the analysis of eclipsing binary light curves. The values of sin²θ and P are used as input. The TI-59 calculator is particularly convenient since it has a built-in least-squares linear fit routine, which can be easily incorporated into a larger program. This program will be used in later sections when particular stars are considered. A listing of the program is presented in Appendix 1. … … Equation (7.1) is solved using a simple iterative procedure.. A program for the TI-59 programmnabie calculator, which performs this calculation, may be found in Appendix 1. … … A program using Tabachnik's method is also Given for the TI-59 calculator. The instructions are self-explanatory. … Appendix 1 Russell Model Programs and Rectification … Russel Model Program solves for the elements of an eclipsing binary (ri,r₂,i) in the case of complete eclipses (ie., total or annular). Method used is a variation of Kopal's method due to V.M. Tabachnik, which fits a line of the form y=ax+b, where y=(1+kp)², x=sin², a=sin²i/r², and b=cos²i/r², (k=r₂/ri). p is the geometrical depth, and is used as input data {use Russell-Merrill tables of α(k,p)}. Elements are given by: tan i=a/b, r=(a+b)-½ r₂=kri (k used as input) … TI PROGRAMMABLE PROGRAM RECORD Depth Equation Solution Solves the depth equation using an iterative procedure. Input data is the limb darkening x (larger star), 1-λ{sub}b[/sub](λ=ℓ(θ) at internal tangency of annular eclipse), ℓα=depth of total eclipse (or value of ℓ(θ) at internal tangency of total eclipse), and an initial estimate of k. … BEST! SlideRule |
