(HP-67) Design Calculations for Passive Solar Buildings
09-30-2024, 01:47 PM
An excerpt from Design Calculations for Passive Solar Buildings by a programmable hand calculator, Lawrence Berkeley Laboratory - U of C - California, August 1979, 84 pages
CONTENTS … PROGRAM OPERATION HP-67 Program … … … 11 TI-59 Program … … … 19 … APPENDIX A: Listing of the … sub-programs … ABSTRACT The behavior of room temperature in a passive solar building without backup heat is of great interest to the building designer. This paper presents programs for card-reading programmable hand-calculators which compute room temperature over the course of a design day. Instructions for calculating the input parameters, and for running the programs are given, and a brief review of the theory is provided. The program can presently be used only for single-zone unmanaged, direct-gain buildings. … This paper presents a hand-calculator program which can be used to predict the floating temperature of a building, given a few simple building parameters and weather data. The calculations describe the building's response to a design day -- that is, a day with idealized {sinusoidal) weather. Two versions of the program are given; one for a Hewlett-Packard HP-67 calculator and the other for a Texas Instruments TI-59. Listings of the program are given in Appendix A. The programs described here can be run in less than one-half hour; in some cases (e.g., those in which a few parameters are varied from an initial design), the run-time is considerably less. The methodology used in the programs can be generalized beyond the level of detail available in the programs. Some of these extensions can be done as hand calculations using intermediate outputs of the programs. Use of this program will allow the building designer to easily predict the floating performance of a proposed single-zone, unmanaged passive solar building. The effect on floating temperature of varying parameters such as properties of the thermal mass and area of windows can be seen and, thus, optimal values can be chosen for such parameters. … The theoretical basis of the programs is described in Appendix B, and de- tailed derivations can be found in Ref. 1. Some familiarity with the theory will be helpful to the user of the programs, as it will assist in evaluating the input parameters to the program. … PROGRAM OPERATION This section describes the operation of the program from the point of view of the user. It assumes that the user has already evaluated all the building and weather parameters. A more detailed description of the HP- 67 and TI-59 programs is given in Appendix C. A listing of the programs will be found in Appendix A. The HP-67 program and the TI-59 program are different in structure, so they are described separately below. The instructions must be followed exactlyto assure correct output. To check the performance of the programs and the selection of input para- meters, a sample problem is set up and solved in Appendix E. … BEST! SlideRule |
